<<<POST YOUR SLAMMED CARS: PART 6>>>
Old 06-10-2007, 07:52 PM
  #29126
1200 Hobos's Avatar
Default Re: (MasterShake)
I'm having the same issue with the front of my da. The rear is tucking and room to go. But the front is all the way down and it isn't tucking. Although I still have the bumps stops and they are a good inch and a quarter/half in length. Am I riding on it? That's why it won't go down any more? If I get rid of it, will it settle down? And if it does, will the car hit the struts on bumps and cause damage?
1200 Hobos is offline
  #29127
EjSex's Avatar
Default Re: (Danronian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian &raquo;</TD></TR><TR><TD CLASS="quote">
Are you running full bump stops w/o extended top hats? I think if you are, you'll need to cut the bump-stops in half. Not sure on this w/Konis, but I know you need to do this on most struts since those factory bumpstops are monsters.</TD></TR></TABLE>
lol it even mentioned in the koni directions for me to cut them in half
EjSex is offline
Old 06-10-2007, 08:41 PM
  #29128
TheTealHatch's Avatar
Default Re: (EjSex)
coilovers all the way down with the perches still
TheTealHatch is offline
Old 06-10-2007, 08:47 PM
  #29129
1200 Hobos's Avatar
Default Re: (TheTealHatch)
The rear of my da looks just like that ^ and I have alittle more room to go. Not happy with the front though. It's barely under. I don't know. I think it's the bumpstop, I'm going to go ahead and cut it in half and see what happends.
Old 06-10-2007, 08:58 PM
  #29130
Danronian's Avatar
Default Re: (RISK ONER)
You should probably cut them at least in half to have any strut travel.
Danronian is offline
Old 06-10-2007, 09:50 PM
  #29131
imeonic's Avatar
BREAKIN' NECKS!
imeonic is offline
Old 06-10-2007, 09:53 PM
  #29132
New User
EkREV's Avatar
Default Re: (nathanong87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathanong87 &raquo;</TD></TR><TR><TD CLASS="quote">
gangsta...makes me wanna get a 350z. hmmmmmmmmmmm...lol
EkREV is offline
Old 06-11-2007, 08:07 AM
  #29133
Danronian's Avatar
I don't know how that gets driven with the rear, tire to fender clearance that tight...crazy ****.
Old 06-11-2007, 08:13 AM
  #29134
nathanong87's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Danronian &raquo;</TD></TR><TR><TD CLASS="quote">I don't know how that gets driven with the rear, tire to fender clearance that tight...crazy ****.</TD></TR></TABLE>
even when it's tight, remember that when a car is lowered ...even when the suspension travels it doesn't travel up and down, but it continues to camber...not "rubbing" if rim/tire fitment is done properly. zilvia.net has the best examples of this
edit: oh i thought u were talking about the Z
nathanong87 is offline
Old 06-11-2007, 08:42 AM
  #29135
ikon_cl9's Avatar
another shot of my car
ikon_cl9 is offline
Old 06-11-2007, 08:44 AM
  #29136
Default Re: (ikon_cl9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikon_cl9 &raquo;</TD></TR><TR><TD CLASS="quote">another shot of my car
Old 06-11-2007, 10:11 AM
  #29137
Danronian's Avatar
I was talking about the Z, but even though the majority of the movement is up and in, there is always some in/out movement on anything with non-solid bushings. But I guess it's not enough to matter. I've never had tire/fender clearance that tight, so I'm not talking from experience in that matter, but I have seen the result of in/out movement on exhausts that were welded to be too close to the tire.
But if it works, awesome. It looks amazing.
Old 06-11-2007, 11:20 AM
  #29138
PatrickGSR94's Avatar
Koni GC's look like this:
The front sleeves w/ springs sitting on the perches:
Flipping the perches would not accomplish anything, except be unsafe because you wouldn't have that lip on top of the perch that fits inside the spring, and the spring could move around on the perch when the suspension unloads (inside wheels around a corner). It's already in the optimal position as pictured above.
But you can move the snap ring on the Koni shocks. With standard Koni Sports for Civics and Integras, you can go another inch lower in front by moving the snap ring to the bottom setting, so that the sleeve will sit 1" lower on the shock.
PatrickGSR94 is offline
Old 06-11-2007, 12:21 PM
  #29139
SjCiViCHB's Avatar
Default Re:
Are you sure your using the lowest clip on the strut? If you flip the collar youre going to really make sure taht adjustment screw is tight, cause they'res no cup for the collar to sit on so if it gets loose, it would just fall off dropping the spring wont it?
SjCiViCHB is offline
Old 06-11-2007, 12:46 PM
  #29140
flipping the perch on a Ground Control sleeve would not let it go as low as if you left it normal. Also the spring would move around when the suspension unloads and probably hit/rub the sleeve and damage the threads, as it wouldn't be centered when it was loaded again.
Flipping the perches upside down on GC coilovers is BAD BAD BAD idea, not to mention pointless.
Old 06-11-2007, 02:01 PM
  #29141
guamie's Avatar
Default Re: (PatrickGSR94)
a friends, not mine. an inspiration to how low i want to go.
guamie is offline
Old 06-11-2007, 02:10 PM
  #29142
im hench irl
skateboard_ej8's Avatar
Default Re: (2oh6civic)
haha yea, most of these guys are runnin 14's 15's 16's, i got 17's so the drop aint as dramatic, but tha muthafucka is tuckin
skateboard_ej8 is offline
Old 06-11-2007, 02:18 PM
  #29143
E46Kid's Avatar
Default Re: (guamie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imeonic &raquo;</TD></TR><TR><TD CLASS="quote">BREAKIN' NECKS!
Rims are a tad to big but overal clean
E46Kid is offline
Old 06-11-2007, 02:21 PM
  #29144
8520's Avatar
Default Re: (Em1Kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em1Kid &raquo;</TD></TR><TR><TD CLASS="quote">Rims are a tad to big but overal clean</TD></TR></TABLE>
Yeah, looks like a matchbox car ha ha.
8520 is offline
Old 06-11-2007, 03:02 PM
  #29145
Sanji
toyomatt84's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by guamie &raquo;</TD></TR><TR><TD CLASS="quote">a friends, not mine. an inspiration to how low i want to go.
That thing's a monster truck.
I'll take this, thank you.
toyomatt84 is offline
Old 06-11-2007, 03:10 PM
  #29146
chunty kevin's Avatar
those ****** wheels dont look that bad on that car
chunty kevin is offline
Old 06-11-2007, 03:11 PM
  #29147
8520's Avatar
Default Re: (chunty *** kevin)
badass gs
8520 is offline
Old 06-11-2007, 03:13 PM
  #29148
JuggsXanvi's Avatar
Default Re: (misanthropist)
throwback *
JuggsXanvi is offline
Old 06-11-2007, 03:26 PM
  #29149
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
neither!
Old 06-11-2007, 03:28 PM
  #29150
emotion's gs only the best parts
Quick Reply: <<<POST YOUR SLAMMED CARS: PART 6>>>
