ENTER THE CHATBOX BRO
I knew you'd say something that has to do with NA, you a hater man. You know how shitty turbo cars didnt your built sohc run normal like once you said?
boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost boost
jseries dumped RHD cut out grill monster front mount on 30 pounds of boost only then will you own da honda game, IF YOU AINT BOOST DAWG YOU SLOW.
makes 600 to the wheels and runs high 12s yeee babyyyy
from my thread
Ok, so i noticed my fuel pressure was going up each day off my b & m gauge. The set up is a jdm b16 brian crower stg 2 cams and vale train. Some aftermarket FPR and a AEM fuel rail, my fuel pressure is supposed to be at around 45 right? well its at 80 lol i havent been driving the car, i check the lines and they were fine and even put a stock regulator on it and the fuel pressure was about the same. Im stumped, could it be the fuel pump or something? HELP
and nope ill have to dl it today antttttt
