The ITR shifter is amazing, I have an ES bushing, but it's a bit hard IMO, should have kept the ITR, it's still way stiffer than the Civic part, but I left it on the HASPORT linkage that I THREW AWAY. Ooops. They make GREAT axles too with 0.050" runout! I guess they're good at using their CNC machine to make badass mounts and brackets though.
Sup guys before i make a thread about this maybe u guys can help me out.
Bought a SIR gauge cluster from ebay, went to install it today and i notice something was missing from the SIR. The lower yellow harness plug. The tach and the obometer works fine but no turn signal. I was wondering if i can swap the stock one on the SIR. Heres pics.
Top is SIR bottom is stock! Let me know what yall think thanks in advance.
As far as the turn signals, do you have your 4-way switch plugged in? If not, that will cause your turn signals to not work.
Let me check about the 4 way switch, so basically i wont need the SRS then? Thanks for your help
That's the best picture I can find. These are the 1st edition rh c2 and yes they're 18s on brand new tires.. Selling the rims and tires.. Too wide so it rubs the inside of the wheel well.
Running status: currently on non op.. Bringing her out of the garage soon.
Yeah that's exactly how I want mine to be. I've tried swapping PCBs, taking the blue covers off the bulbs, ect., and nothing seems to work. I wonder if you have aftermarket bulb in there. Does it light up evenly, or are there like "hot spots"?
I got it off a friend, so not sure if it has "stock" bulbs or not. It doesn't have any more "hot spots" than a normal US cluster with normal bulbs though.
So I'm in a bind on how I want to set up my interior this time.. Could you guys post some photos of yours?
I found a minty set of all gray 97 delsol seats I may pick up, but I was thinking of a possible bucket... I dunno which I should go for
Same goes for some new wheels. Too many choices!
