Old Oct 15, 2010 | 10:41 AM
  #15076
g2_teg_'s Avatar
Yes... why?
because it rides like ****. and i was surprised... my DA was about that low and rode pretty good, i thought.
Old Oct 15, 2010 | 10:48 AM
  #15077
g2_teg_'s Avatar
Originally Posted by Egezzy
depends on the suspension...
Originally Posted by dapek
^^Ya as others said, completely depends on the suspension setup. Being lower will create a relatively worst ride either way, but with cheap suspension components it would be worlds worst than a quality setup.
Koni/GC w/ extended top hats. 380/450 spring rates
it bottoms out on EVERYTHING. sometimes on bumps that i can't even see will make it bottom out. i'm disappointed with this setup so far, i've always been told that its the best. But my Omnipower coilovers seemed a lot nicer.
Old Oct 15, 2010 | 12:09 PM
  #15078
SHG_Claudio's Avatar
Well I was at that height and I would bottom out on some stupid ****. The truth is that tucking tire doesnt look good on a daily. Thats too low man period. Its not the shock travel that matters, its the simple fact that your upper control arms will hit the shock tower first.
I rode that setup in a DA and I was impressed. You just need to raise an inch and half man. The aesthetic value isn't worth having a shitty ride. People will look at it but you're the one driving it.
I just raised my suspension and it rides a lot nicer. No more headaches and it still looks pretty good IMO!
That setup is good man, trust. You're just too low.
Old Oct 15, 2010 | 12:41 PM
  #15079
g2_teg_'s Avatar
thanks for commenting.
I don't think my upper control arms are hitting anything though. It seems i have a lot more clearance there then i have shock travel. once a week i'll take my wheel off and jack up the suspension to see what hits first. I can never get it high enough for anything to hit without getting scared the car will tip, but it gets much closer to the shock hitting the top hats then the UCA hitting the shock tower. Plus, there aren't any scratches on the UCA at all.
Old Oct 15, 2010 | 01:05 PM
  #15080
Mashimaro's Avatar
Originally Posted by TeknitionDc2
thats a very good idea^^. deff dont wanna mess up thos coilovers. Hows the ride after you installed them.
thanks dood!
ride was much better after installing those spacers. i was able to unload the spring pre-load so it did help soften the ride...mind you i'm running 16k front and 14k rear rates so 'soften' is relative
it also helped for removing my wheels and such as this suspension had my tires tucking even when the car was on the hoist...pain in the ***...
Old Oct 15, 2010 | 01:55 PM
  #15081
Egezzy's Avatar
Spongebrad Squarepants
your rates are too low and you have extended top hats. that is why you are bottoming out.
Old Oct 15, 2010 | 02:08 PM
  #15082
UCAs wouldn't have scratches. Regardless of what coilover setup you use, when you ride that low, you are going to sacrifice comfort.
Read this:
https://honda-tech.com/forums/suspension-brakes-54/you-cannot-ride-slammed-have-smooth-ride-2603553/
When you go really low you change the suspension dynamics a lot. They weren't designed to be that low so the components don't work effectively. Its just physics+geometry. You would want bumpsteer correcting lower ball joints to add space between your lower control arm & spindle. That would help fix the angle of the axle & suspension components. There are many things you can do, that is just one of them.
Old Oct 15, 2010 | 07:21 PM
  #15083
g2_teg_'s Avatar
why would the top hats make me bottom out? what rates would you suggest for a car this low and a car this light?
Old Oct 15, 2010 | 07:22 PM
  #15084
g2_teg_'s Avatar
Read this:
https://honda-tech.com/forums/showthread.php?t=2603553
i've read that before, but i honestly didn't think i was slammed.
Old Oct 16, 2010 | 05:26 AM
  #15085
Egezzy's Avatar
Read this:
but by putting in an "extended" ball joint you have effectively increased the distance between the ball joints. that in turn increases the angle of the lca which isnt close to oe either. point being is once you modify your suspension in any way you are compromising something to get something in return. i guess you could say it is almost like newton.s third law of motion.
using extended top hats is to "gain" travel but yet sometimes it can also restrict it. you are raising the mounting point of the damper rod. say before you had the top hats and you would hit a bump at speed. you would bottom out the damper. now with the extended hat you are not bottoming out the damper but you are hitting your uca like mentioned before or tire on body. this is just a general example based on a double a arm fwd honda.
Old Oct 16, 2010 | 07:52 AM
  #15086
Yeah I have never bottomed out my type 1s dampers. Uca hits before.
Old Oct 17, 2010 | 09:40 AM
  #15087
lhd dc2's Avatar
http://www.flickr.com/photos/maceatl/4899768926/http://www.flickr.com/photos/maceatl/4899768926/ by http://www.flickr.com/people/maceatl/, on Flickr
http://www.flickr.com/photos/maceatl/4899175639/http://www.flickr.com/photos/maceatl/4899175639/ by http://www.flickr.com/people/maceatl/, on Flickr
Old Oct 17, 2010 | 10:58 AM
  #15088
phunhaus's Avatar
Interesting rear wing. What is it?
Old Oct 17, 2010 | 03:55 PM
  #15089
dapek's Avatar
Looks like the Bomex one
Old Oct 17, 2010 | 05:08 PM
  #15090
lhd dc2's Avatar
Correct.
I miss my hatch.
Old Oct 17, 2010 | 07:59 PM
  #15091
Rok_Stok's Avatar
I can drive over mt everest without bottoming out.
Old Oct 18, 2010 | 08:46 AM
  #15092
WeakSi's Avatar
http://www.flickr.com/photos/boger/4079009669/http://www.flickr.com/photos/boger/4079009669/ by http://www.flickr.com/people/boger/, on Flickr
Old Oct 18, 2010 | 10:04 AM
  #15093
phunhaus's Avatar
Mine from two weeks ago:
Thanks to Ryan for coming in from Detroit to snap off a few pics!
Old Oct 18, 2010 | 01:07 PM
  #15094
SL0WEGG's Avatar
Bay shot from a car show this weekend. It was a pretty good showing considering they had 2 weeks to set it up. The event was to show local support for a racetrack closer to the cities
Don't mind the speed swirls in my paint lol
Old Oct 18, 2010 | 06:45 PM
  #15095
Kelb's Avatar
few pics i snapped with my droid. GSR swapped.
Old Oct 18, 2010 | 07:17 PM
  #15096
PACU_EG's Avatar
just a simple and clean hatch... not as bad *** as most of ht's hb
Old Oct 18, 2010 | 07:35 PM
  #15097
Dontoh's Avatar
both of you have gorgeous cars.. those burgundy lookin wheels on that black hatch look amazing..
kelb- you ever sand/buff/polish/wax that beast? i love black cars <3
pacu, what color is that?
Old Oct 18, 2010 | 07:40 PM
  #15098
Mashimaro's Avatar
Cool back drop dood! hatch is looking good!
That white VC is nice dood! can't beat displacement
i love those wheels. always wanted a set in 16", gold.
Old Oct 18, 2010 | 07:48 PM
  #15099
PACU_EG's Avatar
@dontoh that's tafetta white
tnx mashimaro!
Old Oct 18, 2010 | 07:49 PM
  #15100
Dontoh's Avatar
tafetta white huh? been lookin for a whitish color for a new paint job.. i just wish i could get more of a reflection outta such a light color
