Old Oct 30, 2009 | 11:30 AM
  #11351
jdmhatchvii's Avatar
Im running jic one piece handles like a ****ing go cart and not to stiff I would recomend them over anything on the market.
Old Oct 30, 2009 | 12:34 PM
  #11352
Rok_Stok's Avatar
^yeah I believe it, those are legendary.
Old Oct 30, 2009 | 01:08 PM
  #11353
American.Graffiti's Avatar
Originally Posted by AH VTEC
HAHA... Its Cool man...
Whats been goin on with You?
Same ole ****. Senior year of undergrad is kicking my ***. I still have a few things to do to my car before I feel its picture worthy. I was driving it around last night and the clutch master cylinder gave out on me so I had to ride home in 1st gear without stopping. lol. That wasn't too bad. I would have worked on it today but the flash flooding didn't help the cause so I'm chilling for today.
Old Oct 30, 2009 | 01:13 PM
  #11354
Scotty Dosent Know's Avatar
The Thing about certain Full Coilovers that I Like over the Sleeve Coilovers... Is that I have more adjustability. I have 18 Way Adjustable Shocks and I can Raise and Lower the car without affecting the spring rate. In my Opinion, For what I do, I'm glad I went with the Full Coilover, I paid Less than the Koni/GC and got more adjustability.
The thing about the adjust ability though is you can adjust it as much as you want but if its inferior on the shock dyno you are just adjusting an inferior shock.
On a koni shock there is pretty much endless adjustability, there are no set knotches you can turn it 1 full turn or turn it 1mm. If full stiff is not stiff enough for you then you can have them re valved which is cheap and most important EASY to do.
As far as pre load with lowering you can adjust the snapring to 3 or 4 different settings down the shock to get the car lower with out sacrificing preload.
Other advantages to having the Koni/GC setup over a 1 piece are lifetime warrenty on both parts and also being able to easily change spring rates.
I had up to 2K to spend on coilovers and ended up with this setup and will prob never go back to anything else because it works so well and is so versatile.
This is from the GC website:
"Ground Control works very hard with Eibach USA to make these springs to the standards that you demand. Lifetime guarantee on everything, not just springs. No excuses about ";racing"; or ";special";. If anything fails, while being correctly installed, it will be taken care of, period. We can only have a guarantee like this because every single part of the Ground Control Street coil-over kit is made by us or someone we trust. None of these parts are made in Taiwan. Everything is made in the USA."
Old Oct 30, 2009 | 01:34 PM
  #11355
AH VTEC's Avatar
How is it an "Inferior Shock" if It is doing what I am telling it to.... 1 Click Hard = Stiffer, or I can increase the Spring Tension without adjusting the shock. Ok a Koni is more consistant on the shock Dyno... Thats Great... I'm not knocking them, they have always had a good product. I'm simply stating that my Coilovers do EXACTLY what I want them to do. I can dial in how stiff or soft I want the car and I can put the car at the exact height I want it at without adjusting Preload. If I want to go Stiffer without adjusting the shock, and I've run out of spring rate, I still have the option to purchase stiffer springs. I've had my Coilovers for over 2 Years with No Complaint. They still ride the same since the day I put them On...
**** Different Setups and different styles make for a great conversation Piece LOL... Thats why the honda World is so diverse.
Old Oct 30, 2009 | 02:57 PM
  #11356
phunhaus's Avatar
Relative spring height (adjusting the perch) has NO AFFECT on the spring rate. I repeat: NO AFFECT on spring rate. An 8k spring will be an 8k spring whether it's up high or down low. Rate is rate and should be constant if it's a quality spring.
And I do Fully understand how my suspension works... I know how to adjust my spring tension and I know how to properly lower a car without using the adjustment on the spring. There are plenty of people that I've helped set up their suspension because they dont fully understand how it works... The first thing they want to do is Lower by the Spring... WHICH IS WRONG... unless you want to take tension off the spring for a softer ride.
It's not "wrong" because how else would you lower this suspension:
Or this one:
I could go on and on but it's clear that you're only used to the new breed of Taiwanese "two-piece" coilovers. Even with a "one piece" coilover you can maintain preload when you adjust the spring perch.
I don't know who taught you, but you need to go back and get the REAL 411 on how your suspension works. Shock damping rate has NOTHING to do with your spring rate, height, or color. How can you adjust ANYTHING related to a spring by twisting a **** on a shock? Think about it. I mean really step back and think about it.
Someone has only given you half of the information and I think you need to stop and think about the simple mechanics of it. Don't worry so much about preload and 900 way adjustability but consider the mechanics of the suspension, what it does, what it prevents, and how the shock and spring work together. You've been bombarded by too many marketing terms. Sort the **** from the facts.
Old Oct 30, 2009 | 04:57 PM
  #11357
AH VTEC's Avatar
I Guess I should Have Specified that I have 2 Piece Coilovers...
I didnt mean to say "Spring Rate" was just trying to say that It defeats the Purpose of a 2 Piece Coilover (like the one pictured above) if you adjust the spring down (Unless you are trying to go Super Low)... The point is to adjust by the Lowest Ring (On 2 Piece Coilover). The coilovers I have adjusted have all been 2 Piece (D2, KSport, PIC's, Omni's, Function and Form, Buddy Clubs, Tein Flex's) I have never personally adjusted a 1 Piece Coilover (Not Including Ebay's LOL) but a couple friends of mine have Tien Basic's (1 Pieces), I am aware of how they work.
You are Exactly Right. I'm not trying to say preload will be changed when adjusting the height down, I was stating that it is pointless to adjust by the spring, once again I should have specified that I was refering to a 2 Piece Coilover. On the 2 Pieces you can add tension to the spring to stiffen the car without sacrificing clicks on the dapener or if you are out of clicks on the dapener. Something you can do to get a car a little stiffer before you have to go up on the Spring Rate... (Cheap Way Out - Obviously not the best thing to do)
I Know... Dapening is the Speed of the Shock which translates into faster rebound for a stiffer Feel. I also realize that adjusting the clicks on the dapener is NOT changing the Spring nor is it adjusting Height. I Said I could adjust the dapener OR adjust spring tension, I Wasn't trying to state that they were related.
I didnt buy my coilovers because I said "Hey Look, 18 Way Adjustability" I bought them because I knew I could get my cars' stance and feel right with these coilovers. There is most often times always gonna be a better and latest and greatest setup coming out, but at the time I bought these, they were the best bang for my buck.
Old Oct 30, 2009 | 06:41 PM
  #11358
Rok_Stok's Avatar
F² are all around nice, my friend who I mentioned earlier, who had the ITR (sold it though ) had the Type-IIs and they rode great. The funny thing is that he got rid of them for Omni Power and he said those were his favorite. He had 3 different sets of coilovers so he could tell the differences.
Old Oct 30, 2009 | 07:43 PM
  #11359
SHG_Claudio's Avatar
Man I'm loving this suspension talk, I've gotta get something after winter. Currently on stock shocks with what I believe to be replica Tein s-tech springs.
Old Oct 30, 2009 | 07:53 PM
  #11360
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I'd enjoy the suspension conversation more if the fellow with the Taiwanese stuff had a better grasp of the English language. It's really difficult to understand what he is trying to say, unfortunately.
And in regard to shock dyno graphs, I've seen a lot of those budget brands with really bad performance numbers; they might have 18 or 36 or 72 clicks of the dial, but those clicks on the dial were in some instances half of the range a stock Koni shock had.
There are good brands and bad brands, but it's a mistake to knock the Koni/GC combination because it isn't as shiny as your favorite.
However, when people bring words like "stance" into it, there's no point in even talking about performance numbers and true suspension theory beyond how you "poke" your wheels and "tuck" your tires.
Old Oct 30, 2009 | 08:58 PM
  #11361
AH VTEC's Avatar
Haha, that's funny. If you could grasp the english language you'd understand that I never knocked Koni/GC, I know they are a great product and I stated that, I know a few people with them and swear by them. Its also funny that you can't "Grasp" the fact that I DON'T TRACK MY CAR (I've stated that numerous times now), but I do daily it, so "Stance" is important to me. Believe it or not not all people who buy suspension are track ****** or care how they compare to the Koni/GC setup on the shock dyno. The fact of the matter is, I don't know everything about suspension and neither do you, so just stop while ure ahead and stop saying that my 18 way adjustable "taiwanese"coilovers are junk. They have been problem free on my car for over 2 years and have done great through the many different settings I've had them on. Its important to you that ure suspension has to perform well on the track, to me, mine has to perform well and be able to be adjusted for my liking for the street. Different parts for different likings and preferences.
Old Oct 30, 2009 | 09:01 PM
  #11362
Rok_Stok's Avatar
Haha, been there done that, that's how my car came when I got it. Sold a Fender Stratocaster to upgrade my suspension. Just got a good deal on a set of Yellows (Koni Sports) and bought some H&R Race springs, very cost efficient, and rides awesome. Yellows really are great shocks. In Kansas City my car rode like a dream, but when I moved to this little hick college town with potholes every 2 feet I had to turn my shocks almost all the way down (not all the way down though, because it descreases the life of the shock). And I was amazed at how smooth these Konis can ride on bumpy roads, compared to how hard they can. The difference between 0 degrees adjustment and 720 degrees adjustment is like comparing snow to concrete. Or something. I keep mine at around 180, then anything past 360 is pure business.
Old Oct 30, 2009 | 09:07 PM
  #11363
Nice man, I am under the impression that KY/H&R springs are the best for the street, the springs arent as stiff as ground controls. I have no idea what I'm getting, but the way I look at it is if Im going to spend big cash then I might as well spend a little more and get something a bit better so not sure if I'll swing with H&Rs since I might as well get GCs
Old Oct 30, 2009 | 09:15 PM
  #11364
Rok_Stok's Avatar
I say if your town is smooth enough for GCs then go for it.
Old Oct 30, 2009 | 09:40 PM
  #11365
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Given your poor use of language, I couldn't tell if you liked either the Konis or the Taiwanese stuff. You were however mentioning several times how you didn't want to effect the spring rate, which lead me to believe you had some sort of inclination into how suspension works and how it will influence the handling of your car; to me I thought you meant in relation to cornering and stability, rather the ability to cope with potholes and speed bumps you encounter on your daily driving adventures to the local watering hole.
However, have a good day, I was just checking in to see pictures of cool hatches, like the one I drove... a decade ago.
Old Oct 30, 2009 | 10:49 PM
  #11366
Rok_Stok's Avatar
Ever thought about getting another one?
Check out the stockness... I think it needs some polished pieces...
Old Oct 30, 2009 | 11:08 PM
  #11367
egwhte's Avatar
Riding dumped is the only way I know.
Old Oct 31, 2009 | 12:38 AM
  #11368
Old Oct 31, 2009 | 06:05 AM
  #11369
k-series's Avatar
That's pretty
Man, I need to get back into powder coating.... /sigh
Steve
Old Oct 31, 2009 | 06:09 AM
  #11370
k-series's Avatar
For the koni/gc crew, anyone using the upper mounts/top hats? Do you lose anything by allowing that much more travel?
Steve
Old Oct 31, 2009 | 07:18 AM
  #11371
SkyeC's Avatar
Boba Connoisseur
25 Year Member
nah... first one got flat-bedded out of a parking lot in the middle of the day in a busy area with people all over. fool me once, sham on you. fool me twice, shame on me.
i like my m3 just fine.
Old Oct 31, 2009 | 08:02 AM
  #11372
Flatbeds to steal cars? I was under the impression that it was a myth. lol. That never happens.
Old Oct 31, 2009 | 08:04 AM
  #11373
dj_wit_dat_eg's Avatar
tow hooks?
Old Oct 31, 2009 | 08:12 AM
  #11374
tum tum 209's Avatar
this happens all the time in san fransico
Old Oct 31, 2009 | 08:49 AM
  #11375
Rok_Stok's Avatar
Isn't it crazy? That's why I hope I get a job with American Honda here in the midwest, like in Marysville, OH, so I don't have to live in CA and be paranoid. I want to enjoy owning my hatch, and I want to be able to park it anywhere I want, for as long as I want. Nobody in my town would even want my car, they think their '88 Silverado is better.
BTW, I'm guessing it's an E46? SMG or manual?
