Old May 7, 2013 | 06:23 PM
  #25876
WhiteSlips's Avatar
Did a leak down and no bent valves, so pretty pumped about that. The crank pulley bolt is damn near welded on though, we had a two foot long breaker bar on it and all it did was bend the crap out of the breaker.... Used a big impact and it won't break the bolt loose. I'll be towing it to a shop soon with a higher PSI air compressor and see if I can't get this turd back on the road.
Old May 7, 2013 | 08:03 PM
  #25877
JDMKid05's Avatar
Best of luck WhiteSlips. Hope to see her back in shape soon!
Old May 7, 2013 | 09:16 PM
  #25878
Scotty Dosent Know's Avatar
That sucks man I would have cut it off by now LOL What is wrong with it?
Old May 8, 2013 | 05:44 AM
  #25879
WhiteSlips's Avatar
I think someone over-torqued it big time and it just doesn't want to come off. Those bolts are made to stretch some, so if it was over-torqued that bad it's going to take some serious leverage to get it out.
I'm going to Lowes today to buy some thick wall steel pipe to see if I can get some more leverage on it. Figured I'd try a little heat too. I also taped up the bottom half of the recess in the crank pulley and filled it up with penetrating oil and motor oil to soak the bolt. If that doesn't work I will have to get it towed somewhere with a 140+ PSI compressor. So frustrating that one damn bolt has been keeping me from driving it....
Old May 8, 2013 | 07:55 AM
  #25880
Greygoose94's Avatar
i had to use a breaker bar that was like 4 feet long to get mine off the b20 it was a bitch.
Old May 8, 2013 | 09:35 AM
  #25881
SHG_Claudio's Avatar
Imagine if the bolt snaps... then you'll be in trouble!
Old May 8, 2013 | 09:40 AM
  #25882
Thats why I was saying I would have cut the head off the bolt by now. Cutting the head off the bolt relieves the tension and he would be able to remove the pulley and probably be able to unscrew the bolt by hand.
Seems like a better solution to me than risk breaking the bolt off inside the crank. I guess it would be fairly difficult to get in there to cut off though, maybe with a dremmel. Been a while since I looked at my crank pulley.
Old May 8, 2013 | 10:13 AM
  #25883
WhiteSlips's Avatar
Don't say that!!!!!!!!!!
There is definitely not enough room in there to do much with the head of the bolt.... If I tried to use a Dremel it would take years to cut through that hardened steel.
Old May 8, 2013 | 08:06 PM
  #25884
EpHatchy's Avatar
The thing with those bolts is its not about leverage but about short hard blasts. Which is what a impact does. Put a breaker bar on it (not a very long one)and smack the handle with a short sledge or heavy hammer.do you have the Honda crankshaft pulley tool?
Old May 9, 2013 | 05:23 AM
  #25885
WhiteSlips's Avatar
I have the Honda crank pulley tool and have it jammed up against the frame rail to where it won't move at all. I have a mini sledge and have tried that on a ~one foot breaker bar and that didn't budge it either. Maybe I can try that again before I put the big boy breaker bar on it though.
Old May 9, 2013 | 08:06 AM
  #25886
That really sucks man! I hope a good impact takes it right off
Old May 9, 2013 | 07:27 PM
  #25887
rajuncajun's Avatar
havnt posted in here yet my first Honda only been havin it for just over a year...
Old May 10, 2013 | 05:12 AM
  #25888
WhiteSlips's Avatar
Looks good! I've never seen that style of one piece headlight before, looks much better than all the other ones I've seen.
Old May 10, 2013 | 05:48 AM
  #25889
JuggerNaut-CTR's Avatar
^Clean car, has a nice look to it. Is a shame that the lip and side skirts were painted tho.
Old May 10, 2013 | 01:09 PM
  #25890
johnn_b's Avatar
Old May 10, 2013 | 01:37 PM
  #25891
yelnats's Avatar
rajuncajun that hatch is sick! what color is that?
Old May 11, 2013 | 01:07 PM
  #25892
rajuncajun's Avatar
I ddnt really want to paint em but they were beat up...just repaired them and paint
Old May 11, 2013 | 01:10 PM
  #25893
rajuncajun's Avatar
Thanks its surf blue
Old May 11, 2013 | 01:13 PM
  #25894
WeakSi's Avatar
Tum Tum I miss seeing pictures of your hatch
Old May 12, 2013 | 05:38 AM
  #25895
Aarron_M's Avatar
My first thoughts too, and then the headlights.
Old May 12, 2013 | 06:02 PM
  #25896
Eddie's Avatar
Master Ninja
Liked it white better. Some OEM headlights and side markers would look alot better.
Old May 12, 2013 | 07:47 PM
  #25897
JDM_EJ8's Avatar
Originally Posted by dirtymicrophone
Car is looking superb, Slips!
I have yet to post pictures in this thread.
Just picked up some new wheels and am in the process of getting the hatch ready for IA in Texas.
reminds me of my hatch
Old May 13, 2013 | 08:08 PM
  #25898
yeisonSI's Avatar
here is a picture of my hatch.
Old May 13, 2013 | 10:47 PM
  #25899
mADmAN-86's Avatar
hey guys........ i need some education on JDM EG6 rear wings...and i need it quick
i wanna install a GT Wing (replica J's Racing wing) and i know that they require the stock wing to be mounted... and my current CF Duckbill aint gonna work with it...
ive found 2 different wings... can anyone tell me which wing is more suitable to mount the GT Wing? or will either one of them work...
FYI, i dont even know if theyre the same wing... or different type of wings (1 pc and 2pc) never really known much about the stock wings.
heres some pictures
Seller 1
Seller 2 (only picture he provided to me)
which spoiler will be more suitable for the GT Wing? or are they both usable?
help me pleaaaaaaaaasseee
Old May 13, 2013 | 11:04 PM
  #25900
Haylex's Avatar
Js wing will fit on either. They will even fit on a stock non jdm wing, the third mounting point is just not used and hangs over the edge
