del Sol thread v 2.0!
Old Feb 6, 2007 | 11:02 AM
  #17101
james p.'s Avatar
Default Re: (solerizr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solerizr &raquo;</TD></TR><TR><TD CLASS="quote">Your gonna have to get more agressive probably to take that orange peel out the way you want james.
Race glaze is just a polishing compound, rather than an abrasive, cutting compund.
"cut" = sanding off a layer or two.
Now, you will have to excuse me, its 60* out for the first time in months, im ditching class to be outside; bye.</TD></TR></TABLE>
a) How much more aggressive? Start with 800 grit?
b) "Cutting" doesn't sound to appealing...
c) Do I really need 2 different compounds? This is getting confusing.
Old Feb 6, 2007 | 11:08 AM
  #17102
black94sol's Avatar
Default Re: (james p.)
WWWAAAAHHHOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
i found out my date for leave
I CAN'T WAIT!!!!
35 DAYS AND COUNTING!!!!!!!!!!!!!!!!!!1
Old Feb 6, 2007 | 11:11 AM
  #17103
skip.two's Avatar
35 days is a lot better than 5 months
Old Feb 6, 2007 | 11:13 AM
  #17104
black94sol's Avatar
Default Re: (skip.two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip.two &raquo;</TD></TR><TR><TD CLASS="quote">35 days is a lot better than 5 months </TD></TR></TABLE>
well sadly i have to come back to this god forsaken place but only for like 3-4 months
Old Feb 6, 2007 | 11:15 AM
  #17105
skip.two's Avatar
Default Re: (black94sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black94sol &raquo;</TD></TR><TR><TD CLASS="quote">well sadly i have to come back to this god forsaken place but only for like 3-4 months </TD></TR></TABLE>
how many days/weeks/months after this leave though?
Old Feb 6, 2007 | 11:16 AM
  #17106
black94sol's Avatar
should be about 16-18 weeks or so, then i'm home for good.
but man i gotta go, i'm almost off work. might ***** it up a lil bit if our net is up
Old Feb 6, 2007 | 11:31 AM
  #17107
imm0rt41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james p. &raquo;</TD></TR><TR><TD CLASS="quote">The first time you drive a del Sol is like the first time you have sex. It isn't that great, but the smile on your face makes you coming back for more and more!</TD></TR></TABLE>I couldn't have put it better...you made it into my sig
I picked up my rear tranny bracket for my swap, as well as the two-bolt driver's side mount...just need a tranny, front tranny bracket, tranny mount (mine is for an auto so it needs either a spacer ot to be replaced with longer manual one), clutch/pressure plate, and shift linkage before the motor is in the car.
So are you guys sure ITR shift linkage won't work in a sol? I have two friends who say they have done it and it fit fine, but then someone in here said no. I must know!
Old Feb 6, 2007 | 11:33 AM
  #17108
solerizr's Avatar
c) Do I really need 2 different compounds? This is getting confusing.</TD></TR></TABLE>
I cant remember what i started with.... but if i remember right, i did like 5 or 6 steps of just sandpapers: i think i went over the car for one reason or another something like 10 times.
And if you want it to turn out really shiny, you will want 2 different compounds.
Old Feb 6, 2007 | 11:40 AM
  #17109
james p.'s Avatar
Default Re: (imm0rt41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imm0rt41 &raquo;</TD></TR><TR><TD CLASS="quote">I couldn't have put it better...you made it into my sig </TD></TR></TABLE>
Rock it like you mean it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solerizr &raquo;</TD></TR><TR><TD CLASS="quote">I cant remember what i started with.... but if i remember right, i did like 5 or 6 steps of just sandpapers: i think i went over the car for one reason or another something like 10 times.
And if you want it to turn out really shiny, you will want 2 different compounds.</TD></TR></TABLE>
10 times? Did you even leave any clearcoat on? A bit of an overkill don't ya think? But I guess you know from expirience... I can't wait till friday to start on my extra fender and headlights.
Old Feb 6, 2007 | 11:43 AM
  #17110
solerizr's Avatar
10 times? Did you even leave any clearcoat on? A bit of an overkill don't ya think? But I guess you know from expirience... I can't wait till friday to start on my extra fender and headlights. </TD></TR></TABLE>
Integrated clearcoat
Old Feb 6, 2007 | 11:54 AM
  #17111
skip.two's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imm0rt41 &raquo;</TD></TR><TR><TD CLASS="quote">So are you guys sure ITR shift linkage won't work in a sol? I have two friends who say they have done it and it fit fine, but then someone in here said no. I must know!</TD></TR></TABLE>
you'll need the VTEC shift linkage.
Old Feb 6, 2007 | 11:55 AM
  #17112
del Slo SiR's Avatar
Whats up James cant help but notice your lil dilema...well when I was the parts guy at the body shop where my sol was painted I picked up a thing or two...
wet sand with 1500 Grit 1st (3M sand papaer is good stuff)
then sand with 2000
then buff with 3M rubbing compound
Then Wax and bam u are done...
Try to keep your hand flat while sanding...
Its a good idea to cover the drain vents under the windshield with newspaper...
tape off all the rubber and plastic pieces...
be careful on ridges because its easy to get carried away and burn the paint...
Old Feb 6, 2007 | 12:00 PM
  #17113
skip.two's Avatar
Default Re: (delSloSiR626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSloSiR626 &raquo;</TD></TR><TR><TD CLASS="quote">wet sand with 1500 Grit 1st (3M sand papaer is good stuff)
then sand with 2000
be careful on ridges because its easy to get carried away and burn the paint...</TD></TR></TABLE>
this is the method i had in mind
Old Feb 6, 2007 | 12:02 PM
  #17114
foam's Avatar
I'm in the same boat as james. My Sol hasnt been wetsanded after the paint job so it has a lot of orange peel. Do you know the average price of a wetsand and buff? I'm thinking about getting someone to do it for me since I'm not too excited about sanding my car lol. I still gotta find out if my car is 1 stage paint or not otherwise I'm stuck with this orange peel
Old Feb 6, 2007 | 12:03 PM
  #17115
hothotpete's Avatar
Default Re: (foam)
yeah, so today in the midst of the snow and unpaved streets, i got hit by a school bus. i'll post pics up later. anyways, anyone got a passenger side door for sale???
Old Feb 6, 2007 | 12:06 PM
  #17116
skip.two's Avatar
Default Re: (hothotpete)
ouch.
Old Feb 6, 2007 | 12:07 PM
  #17117
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hothotpete &raquo;</TD></TR><TR><TD CLASS="quote">yeah, so today in the midst of the snow and unpaved streets, i got hit by a school bus. i'll post pics up later. anyways, anyone got a passenger side door for sale???</TD></TR></TABLE>
Too bad u not i so cal there is a pass side at the junkyard...I got a driversideone for 20 bux
Old Feb 6, 2007 | 12:09 PM
  #17118
hothotpete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSloSiR626 &raquo;</TD></TR><TR><TD CLASS="quote">Too bad u not i so cal there is a pass side at the junkyard...I got a driversideone for 20 bux </TD></TR></TABLE>
hmmm, my gf lives in SD. maybe she can ship it to me....
....nah. good looking out. if anyone else has one lying around, let me know. i'll GLADLY take it off your hands
Old Feb 6, 2007 | 12:15 PM
  #17119
So yeas decided to get another door cuz if u look closely its a lil wavy from the bondo...
Old Feb 6, 2007 | 12:21 PM
  #17120
damn got to go outside and start putting the Sol back together...
Old Feb 6, 2007 | 12:23 PM
  #17121
LowSlow93Sol's Avatar
For you guys looking to wet sand the cars be sure to use a hard rubber sanding block instead of your hand. Carefull on the edges though.
I have a Little bit of orange peel on my door I may try to work out this spring. using this method.
Old Feb 6, 2007 | 12:24 PM
  #17122
black94sol's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSloSiR626 &raquo;</TD></TR><TR><TD CLASS="quote">damn got to go outside and start putting the Sol back together...</TD></TR></TABLE>
sweet, better get on that
34 days and i'll be doing the same thing
the sol will be painted
Old Feb 6, 2007 | 12:25 PM
  #17123
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black94sol &raquo;</TD></TR><TR><TD CLASS="quote">sweet, better get on that
the sol will be painted </TD></TR></TABLE>
Sweet! How much will it cost you for new paint?
Old Feb 6, 2007 | 12:27 PM
  #17124
I'm painting the hatch next month...
Old Feb 6, 2007 | 12:34 PM
  #17125
black94sol's Avatar
Default Re: (LowSlow93Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowSlow93Sol &raquo;</TD></TR><TR><TD CLASS="quote">Sweet! How much will it cost you for new paint?</TD></TR></TABLE>
ya know my pops never said *dunno*
but it will look a lot better than black, black primer, grey primer
