del Sol thread v 2.0!
Hi mates I have a quick question. Here in Australia I have a 92 crx targa top With a
B16a. But in the USA its called a Del Sol or a civic in other forums? Im just trying to get as much info on the model itself. So if there's any info you guys would like to share I'ld really appreciate it. (Ill post pics as soon as I can)
Thanks in advance.
Thanks in advance.
Here in the UK the UK models are technically called civic crx. The imports are called delsols. But they obviously both share an EG civic chassis etc.
Not sure if you aware of the UK forum, www.delsoluk.com but take a look and feel free to ask anything
EDM can also be classy. Let me present you my girly Turbo Flowers (Motegi version with B18C4 swap + GT28RS = 282HP @ 0.4b)
Why there is no male hostesses?
Most unique mod I ever did: a dog spot
[IMG]
[/IMG]
[IMG]
[/IMG]
I've been lurking around this thread for a long time. Don't ever think I've posted a pic of my sol. Well here's a few.
Specs:
d16y7 Block
Stock sleeves bored to 75.5
Golden Eagle Block guard
CP Pistons 9.0:1
Eagle rods
ACL race bearings
ARP headstuds
OEM Headgasket
Stock d16y8 Head
Transmission:
ACT Extreme pressure plate
Street disc
Lightened Stock Flywheel
Fuel System:
Walbro 255hp fuel pump
AEM fuel rail
Aeromotive FPR
Deatsch Werks 800cc saturated injectors
Exhaust:
GReddy Evo 2
Quicktime Performance 3" cutout
Turbo stuff:
Precision SC61S .63 a/r
Ramhorn mani
3" downpipe (DEI wrapped)
Tial 38mm wasetgate
Turbo elements Back door intercooler (24x8x3.5" core) Anodized black
2.5" intercooler piping
Tial 50mm BOV
Electronics:
P28 ecu (OBD1)
Hondata S300
Hondata Boost Solenoid
Hondata 4 Bar MAP sensor
Apex'I turbo timer
Autometer Boost (30psi), water temp, A/F, and oil pressure gauges
Other:
Energy Suspension motor mount inserts
Fluidyne Radiator
Moroso Catch Can
Hondata Intake Manifold Gasket
Suspension/Wheels/Brakes:
Full-Race Traction bars
Omni Power Drag Coilovers Front and Back
15" Rota Slips w/ Falken Zeix's
Black protective coated OEM calipers
Stoptech Powerslot Rotors
Hawk HPS Pads
Stainless braided brake lines
Interior/Exterior
Type R style civic front lip
Type R Shift Boot
Type R Brake Boot
Mugen Racing II Steering wheel
NRG hub with quick release
Security
Yes.
320.74whp and 253.80ftlbs @ 15psi @ 7.5k (Cut out closed/Full Exhaust)
Coming in the next month:
Fully built head - Bisi 3.6 Cam, Valvetrain, PnP, GE manifold, etc. etc.
Tranny build - Spec mini twin clutch, MFactory LSD, stonger axels.
New tune. Going for 5-600whp.
As soon as I get a day off I'm replacing the Type-R style lip with a Mugen style lip... Made for a del Sol...
Specs:
d16y7 Block
CP Pistons 9.0:1
Eagle rods
ACL race bearings
ARP headstuds
OEM Headgasket
Stock d16y8 Head
Transmission:
Street disc
Fuel System:
AEM fuel rail
Aeromotive FPR
Exhaust:
GReddy Evo 2
Turbo stuff:
Ramhorn mani
Tial 38mm wasetgate
Tial 50mm BOV
Electronics:
P28 ecu (OBD1)
Hondata S300
Apex'I turbo timer
Other:
Fluidyne Radiator
Moroso Catch Can
Hawk HPS Pads
Interior/Exterior
Type R Shift Boot
Type R Brake Boot
Security
Yes.
I want to see just what the stock sleeves are made of. I'm hoping that they'll take me to 500. Eventually I'll sleeve the block.
Also, my car will never be a track only car. I plan on keeping my full interior and everything else. I've already talked with several fabricators about a 6 or 8 point cage that will retain it all and keep functionality.
Full interior and a full cage is definitely a challenge, but can be done. Makes for a tight squeeze if you're over 6' tall lol.
And of course, targa top functionality is still 100% there
Why does it sound like a mess?
Very nice. That is what I aim to do with the cage. Is your rear window still functional, or did your cage go through the rear wall?
Mess to clean up when it pops
Thanks. Had to sacrifice the use of the rear window to have a properly built cage with bars running to the rear.
