del Sol thread v 2.0!
Old Jan 5, 2010 | 10:57 AM
  #106301
trustdestruction's Avatar
Default Re: del Sol Owner's Club Thread v 2.0!
I have Kicker 5 1/4" components up front and Kicker 6 1/2" midbass drivers in the rear (components without the tweeters). I would have 6 1/2" all around but I got the 5 1/4" speakers for a great deal.
2 10" MA Audio subs in the trunk for the low frequencies, gain not turned up too high.
I like the sound I get from it, it seems like I hear every audible frequency of the music pretty clearly.
Old Jan 5, 2010 | 11:08 AM
  #106302
imm0rt41's Avatar
Originally Posted by gen2tegboi
you guys running an amp to speaker or just matched with an aftermarket unit?
no amps for me, just the premiere speakers with a pinoeer premiere deh-4700mp head unit lol
Old Jan 5, 2010 | 02:03 PM
  #106303
Type_R_Nammer's Avatar
I'm using Alpine Type S SPS-600's front and rear, for 65 bucks a pair, can't go wrong.
Old Jan 5, 2010 | 02:15 PM
  #106304
z6htch's Avatar
Originally Posted by Eran
Anyways....
Found a switch I may use for my foglights. Got it at Autozone for like $10, and it's really neat. Heat-sensitive touch pad, completely flush.
I think I have it upside down in that photo, because when I had it in before, there wasn't a gap. It needs a little rubber gasket around it, because the body is a little thinner than a stock switch.
Video with functioning.
http://www.youtube.com/watch?v=kSae-ePkR4U
Red = OFF
Blue = ON
Ha thats great. I had the same switch in my sol in that spot. It worked great and fit pretty good. Now its in my eg on the armrest. Never seen anyone else try that idea, props to you brother.
Old Jan 5, 2010 | 04:20 PM
  #106305
95Sol99civic's Avatar
Can anyone tell me what speakers you are running (front and back) on the Sol? I wanna see what Solers prefer, I am running stocks and I definitely need new ones. I am looking to run them with my pioneer unit (no amp or subs).
I am running 6 1/2 MTX components front and 6 1/2 lightning audio 3ways in the back sounds great could use an amp if I ever get a bigger sub...www.onlinecarstereos.com has alot of cheaper high end stuff
Old Jan 5, 2010 | 06:18 PM
  #106306
So Mugen bumper with upper aux fogs? Where do I get this bumper? Thanx
Old Jan 5, 2010 | 06:23 PM
  #106307
eg2 row's Avatar
i have one but not connected yet dont really need it right now
Old Jan 5, 2010 | 06:25 PM
  #106308
eg2 row's Avatar
up date on my car=
they did my quarter panels perfect!!!!!!!!!! im loving every single moment
Old Jan 5, 2010 | 06:49 PM
  #106309
Rat_Bear's Avatar
I wired up loglights with my stock switch. Does anyone know how to wire it up so it makes the switch work at anytime the car is on?
Old Jan 5, 2010 | 06:54 PM
  #106310
I can tell you how to make the switch turn on the AUX lights as long as the headlight switch is on (whether it be parking lights, low beams, or high beams).
(black bulge is a crimp cap, lol)
Old Jan 5, 2010 | 07:02 PM
  #106311
^^ thanx wondered bout that.
Old Jan 5, 2010 | 07:04 PM
  #106312
I hooked up the ones on my hatch to the fuse box. Use a test light and turn on the key
Old Jan 5, 2010 | 08:21 PM
  #106313
markspan6243's Avatar
Flattery Will Get You Everywhere
hey i want to get a wink mirror for my sol, but i dont know how to get the stock rear view mirror off, how do i do it? i know eran did it
Old Jan 5, 2010 | 09:04 PM
  #106314
ali954's Avatar
i actually cracked my windshield trying to get it off. i ended getting my windshield replaced and watched the guy do it and all you gotta do is basically slid the whole thing up. use a big screw driver and hammer. he just gave it a quick hard tap and it came right off. i was kinda pissed lol
Old Jan 5, 2010 | 09:11 PM
  #106315
be sure to remove the set screw first! don't just go tugging/hammering on ****
Old Jan 5, 2010 | 09:40 PM
  #106316
B16DelSlo's Avatar
i need a wiring diagram for the jdm 1 pieces? i noticed i can just use the stock plugs for the headlights and corners? but i just tap the city lights the the corners?
Old Jan 5, 2010 | 10:03 PM
  #106317
mdrshewrote's Avatar
I was able to use the OEM plugs for my JDM headlights they work just fine for me for the H4h bulbs but modded my H4 HID's snugged in tight. Corners I used my OEM too as well, they do fit you just gotta turn it good. City lights I tap them onto the power of the headlight harness which is the top area and wire the other to your parking so that way your city lights turn off when you use your headlights. Correct me if i'm wrong.
Old Jan 5, 2010 | 10:09 PM
  #106318
But aye B16DelSlo wussup with that trade? I need more info and each wheel pic, I'll do the same. I remember you said you got some curbage in stuff. How are the tires? They aren't Rotas right? hahahaha don't wanna drive all that way in ****.
Old Jan 5, 2010 | 10:21 PM
  #106319
That won't work the way you said it will.
I'm not sure if this is the conventional way to make it work like that, but to make the city lights on when the headlights are off you could use an SPDT relay.
To do it that way, you would cut the low beam 12V wire on the headlight bulb harness (leave plenty of wire on each end). On the SPDT relay run relay pin 85 to the wire end on the main part of the harness, then pin 86 to the end that goes to the bulb harness. Then run pin 30 to the 12V wire for the parking light (constant with parking lights on). Then run pin 87a to the city light's 12V wire. Ground the city light's ground wire. Pin 87 on the relay will not be used.
You should then get power to the city lights when the headlights are off but the parking lights are on. Then when you turn the headlights on the city lights will turn off. The only downside is that the city lights would be on if you use the high beams.
Old Jan 5, 2010 | 11:49 PM
  #106320
Or that...I guess I did it the ghetto way then by following the Power wire from the headlight harness/plug whatever and wiring to my city light and the other to parking lights to the city light. I believe the city lights have 2 wires? and it still did the job. But i'd perfer going with your idea. I'm having trouble with my HIDs, one will just stay on and i have to keep on flickering it til the other turns on maybe its my power wiring on my plug or my ballast is goin down on me.
Old Jan 6, 2010 | 02:59 AM
  #106321
Use a flat head screw driver, there's actually a tiny slit for a flat head to fit into it.
Old Jan 6, 2010 | 05:07 AM
  #106322
mugen-k's Avatar
a lil late to the question and probably not the answer you're looking for but thought i'd post that i'm running:
JDM Optional 6 Piece Gathers System w/ Tweeters:
I wanted to complete the set and use the headunit as well but went with function/practicality instead and got a new Sony MEX-BT300 Bluetooth stereo with iPod/USB input on the front.
Old Jan 6, 2010 | 06:45 AM
  #106323
eg2 row's Avatar
where u get those tweeters??
Old Jan 6, 2010 | 06:54 AM
  #106324
eg2 row's Avatar
those kinda look like type r rims
Old Jan 6, 2010 | 07:15 AM
  #106325
hyperEG1's Avatar
I like the color too!
