<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen2_4door »</TD></TR><TR><TD CLASS="quote">Finally fixed the idle problem guys! Just like i was told, it was the FICV and it was totally broken. The ball or whatever innside of it just rattled like crazy. So i've finally got a normal idle again! I also found the leak in the hard PS line. I'm thinking i'm just gonna make an attempt to cut the line and use a high pressure hose to replace it. We'll see how that goes.
i have the high pressure hose if thats what you're talking about. let me know if you need it. I thought i had a leak from it, but it was my actual pump seals inside the ps pump so i changed that and no more leak
</TD></TR></TABLE>i have the high pressure hose if thats what you're talking about. let me know if you need it. I thought i had a leak from it, but it was my actual pump seals inside the ps pump so i changed that and no more leak
Naw its actually a fracture in the hard pipe just off the end of where it meets up with the reservoir. But i've still got the old sedan sitting in the driveway so if i need it i'll just pull it off the other car. Thanks tho man
Hey guys..I just finished designing a decal for my db1. I'm about to order it but was wondering if you guys would be interested in it as well. If so, please let me know so I can order them in bulk and sell them back to you. Price per decal would be between $3 to $4 shipped and would be about 7" lengthwise. I would have a definite price when I hear back from you guys and submit the order for a price quote.
Anyways..here's the design:
Decal will be white car outline, with white lettering and the red heart.
I made the outline from this:
Went for a clean outline, and small letters so the decal looks as clean as possible..did not want a bunch of big words on the bottom of it so this is what I came up with..Let me know if you guys are interested and maybe I can get these printed very soon...
Let me know...
I'm going to start a list, from here and from the DB1 thread over at HT. I'll keep updating it.
I love my db1 Decals List (members from G2IC & HT)
Sammyloski (x2)
Polska11111
DarkDB1 (x2)
rexone (x2)
gen2_4door
frozenrice (x2)
b204door
integra_661(x2)
db1love
91-lsvtecsi (x2)
Modified by Sammyloski at 10:04 AM 2/29/2008
Let me know...
Sammyloski (x2)
Polska11111
DarkDB1 (x2)
rexone (x2)
gen2_4door
frozenrice (x2)
b204door
integra_661(x2)
db1love
91-lsvtecsi (x2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rexone »</TD></TR><TR><TD CLASS="quote">sammyloski- put me down for two stickers. ian got you brotha.
all right, I'm keeping a list so I'll get back at you guys, in the meantime lets see how many more people I can get, because for the 3-4 dollar price I need to order in bulk!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen2_4door »</TD></TR><TR><TD CLASS="quote">sammyloski- put me down for two stickers. ian got you brotha.
all right cool man, I'll put you down as well..let me know about the bra!
</TD></TR></TABLE>all right, I'm keeping a list so I'll get back at you guys, in the meantime lets see how many more people I can get, because for the 3-4 dollar price I need to order in bulk!
</TD></TR></TABLE>all right cool man, I'll put you down as well..let me know about the bra!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondalover91crx »</TD></TR><TR><TD CLASS="quote">hey rex what are you running for an exhaust? are you guys using 2dr axle backs with dc 4 door mid pipes?</TD></TR></TABLE>
rex has the RSR and i have the greddy sp2.. the greddy sp2 came with an extension piece for a 4dr
the difference between the catback on the coupe and the sedan.. the sedan is a couple inches longer.. other then that.. everythings the same
sinful how do you like your sp2 and rexone how is your rsr. i cant decide between the two. does one have more clearance from the floor than the other since my stock exhaust scrapes when i go up driveways. just thought i would ask since you guys have the opportunity to compare them next to each other. if you dont mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinfulDB1 »</TD></TR><TR><TD CLASS="quote">may be a shot in the dark... but what if u try to patch it.. how big is the hole
Well its actually where the two hardlines are run next to each other and welded together with the little bracket thing. What could i use to patch it? I can somewhat weld/solder so if i knew what to use, i could probably do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 831db1teg »</TD></TR><TR><TD CLASS="quote">sinful how do you like your sp2 and rexone how is your rsr. i cant decide between the two. does one have more clearance from the floor than the other since my stock exhaust scrapes when i go up driveways. just thought i would ask since you guys have the opportunity to compare them next to each other. if you dont mind.
well both of our cars are low as ****.. so i think we BOTH equally scrape exhaust. what usually scrapes is the resonator, since its dead smack in the middle of the car.. and the lowest point of the exhaust..
i love my sp2 though.. its not loud.. but if you give it a little gas.. you wont forget its there
Well its actually where the two hardlines are run next to each other and welded together with the little bracket thing. What could i use to patch it? I can somewhat weld/solder so if i knew what to use, i could probably do it. </TD></TR></TABLE>
i know what two lines youre talking about.. that must be a bitch with the motor STILL in the car...
wonder if you could even use jbweld.. i think its worth a try dude.. what is there to lose? power steering fluid? might as well
</TD></TR></TABLE>well both of our cars are low as ****.. so i think we BOTH equally scrape exhaust. what usually scrapes is the resonator, since its dead smack in the middle of the car.. and the lowest point of the exhaust..
yeah i may just try throwing some on tomorrow. Hell i've been through 2 quarts in the past couple days trying to figure out where it is and what to do with it all while driving the car daily.
Also, I'm on the market for a new set of lugnuts. I've been looking into the Project Kics and the Muteki Neo Chrome sets, but cant justify spending the $200 for the Kics. I can get a set of the Muteki's for $100 shipped. You guys know of anything better?? I want something that will look great with the volks, but want them to be practical and EFFECTIVE! I dont want the wheels stolen!! Let me know what you guys think
</TD></TR></TABLE>yeah i may just try throwing some on tomorrow. Hell i've been through 2 quarts in the past couple days trying to figure out where it is and what to do with it all while driving the car daily.
kics are gangster... i have volk extended lugs.. they look good on the te's
</TD></TR></TABLE>kics are gangster... i have volk extended lugs.. they look good on the te's
yeah i love my rsr exhaust as well. its sounds stock until you floor it. it has a deep sound with no raspiness. you wont go wrong with either one.
</TD></TR></TABLE>yeah i love my rsr exhaust as well. its sounds stock until you floor it. it has a deep sound with no raspiness. you wont go wrong with either one.
Man i would love to get a set of Rays but they're just as expensive as the Kics anymore!!! No here's a retarded question for you guys, would i be alright running extended lugs on stock studs???
</TD></TR></TABLE>Man i would love to get a set of Rays but they're just as expensive as the Kics anymore!!! No here's a retarded question for you guys, would i be alright running extended lugs on stock studs???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra_661 »</TD></TR><TR><TD CLASS="quote">oh and hey my friend wants a sticker to so 2 for me and let me know whats up Sammyloski
all right man, cool...I'll add you to the list..
</TD></TR></TABLE>all right man, cool...I'll add you to the list..
Man i would love to get a set of Rays but they're just as expensive as the Kics anymore!!! No here's a retarded question for you guys, would i be alright running extended lugs on stock studs???</TD></TR></TABLE>
yeah you can run extended lugs on stock studs
they arent bad.. u can usually find a good set here on hondatech for 100
but if you arent trying to spend that much.. just get some black muteki lugs from ebay.. u can get em for 30 or 40 bucks.. those or even kyokugen.. ive had both sets for years with no problems
