DA Integra's Only
Old Oct 13, 2006 | 10:42 PM
  #10276
ultra tegboi's Avatar
Default Re: (Mattb16teg)
what the hell does that have to do with this thread? try creating a new thread..
Old Oct 13, 2006 | 10:46 PM
  #10277
90_DA's Avatar
Default Re: (Pacifier)
sexy da6 man sad to hear it was stolen :'(. What suspension were you running?
Here's more pics of my DA6 ..
NEEDS to be lowered...and OEM kits needs to be painted and installed!!! ..
Old Oct 13, 2006 | 11:31 PM
  #10278
jdmkrazie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattb16teg &raquo;</TD></TR><TR><TD CLASS="quote">Ok fellas need some help
MY bone stock 90 CRX SI:
It runs fine, Ive driven it on 300 mile trips with no problems, burns a little oil but what 17 year old car doesnt.
The problem is, when starting it, on random occurences it will idle and right away die. But some days it starts up right away first try. I have tryed to associate this with temperatures and any other conditions I can think of and nothing, just random times. Put simply its like starting your car and immediately turning the ignition off. The only things I can think of/and am replacing tomorrow are the fuel filter and dizzy. It has new plugs as of 2 weeks ago. Im trying to get a TPS and IAC. Anybody ever have this problem on any of their cars?
Thanks! </TD></TR></TABLE>
i'll try to help you out.. check those 2 you were saying tps and iac. but also check your main relay (doesn't really seem like it would be... but i'm leaning more towards the tps)
Old Oct 14, 2006 | 03:16 AM
  #10279
Pacifier's Avatar
Default Re: (90_DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_DA &raquo;</TD></TR><TR><TD CLASS="quote">sexy da6 man sad to hear it was stolen :'(. What suspension were you running?
Cheers man.Suspension wise I just had some shortened KYB shocks and some rather low Jamex springs.Sat around 90mm off the ground (chassis).
Now I just have a pretty much stock Taffetta white JDM DA9 with matte black dc2 rims (fat fives),going to install some Jamex Superlows in the next couple weeks,then going to do some cheapy extractors through my work and make my own exhaust (2 1/4" press bent pipe with 2 resonators and an N1 style muffler.
Then getting the new alarm installed,and the search will be on for a decent b16a2 head to be freshened up and slapped on the b18a block,and then tuned with CROME.
Old Oct 14, 2006 | 07:22 AM
  #10280
RHDintegXsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pacifier &raquo;</TD></TR><TR><TD CLASS="quote">Just thought I'd post up some old pics of my old JDM DA6 before it was stolen couple years ago
damn integras aren't safe anywhere, not even New Zealand
Old Oct 14, 2006 | 07:41 AM
  #10281
teg91's Avatar
Mod List: Bomz intake, Magnaflow cat-back exhaust, B&M shifter, polyurethane shifter bushings, NGK V-Power plugs, MSD modified cap, MSD extreme rotor, MSD SS Blaster coil, Moroso wires, strut bar, NO AC components, cut out center of front bumper, shaved rear emblems, clear corners, super yellow fog light bulbs
Old Oct 14, 2006 | 08:28 AM
  #10282
kb8thekid's Avatar
Default Re: (jonsteR)
i will not. i will always be kb8, kb24 doesn't sound the same.
Old Oct 14, 2006 | 08:29 AM
  #10283
kb8thekid's Avatar
Default Re: (uniqueredlude)
thank you sir.
Old Oct 14, 2006 | 09:16 AM
  #10284
kb8thekid's Avatar
Default Re: (kb8thekid)
one from work.
Old Oct 14, 2006 | 09:29 AM
  #10285
Brice.Hayden's Avatar
Default Re: (PandaHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch &raquo;</TD></TR><TR><TD CLASS="quote">Ehh whatever, hahaha, no harm no foul. I do applaud you for honestness. </TD></TR></TABLE>
don't you mean honesty? wow highschool have i met you before?
Old Oct 14, 2006 | 10:05 AM
  #10286
Pandahatch's Avatar
Wow have you met a kick in the *****? What you are trying to say absolutely makes no sense what so ever. Honestness, noun - the quality of being honest. Expand your vocabulary retard. Wow, highschool have I met you? ****** dumbass.
Old Oct 14, 2006 | 10:33 AM
  #10287
Mattb16teg's Avatar
Community Builder
Community Influencer
Thanks for some input jdm krazie, but I think if it were the main relay that it wouldnt run at all.
And to the other kid: eat a dick!
Old Oct 14, 2006 | 12:24 PM
  #10288
K.Quinn's Avatar
noob question...how do you turn your fogs on without the headlights on ?
Old Oct 14, 2006 | 01:09 PM
  #10289
Jose-aka-Pedro's Avatar
Default Re: (Semi-FlatDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Semi-FlatDA9 &raquo;</TD></TR><TR><TD CLASS="quote">noob question...how do you turn your fogs on without the headlights on ? </TD></TR></TABLE>
G2ICteg tips, http://www.G2IC.com
You rewire them,
Modified by Jose-aka-Pedro at 11:30 PM 10/14/2006
  #10290
bks84's Avatar
Loved
go to g2ic.com and then to teg tips, then to lighting... then to 'rewiring fogs'
http://g2ic.com/tegtips/lighting/1.html
Old Oct 14, 2006 | 01:27 PM
  #10291
Default Re: (4sd4dr)
Bump....
Old Oct 14, 2006 | 01:44 PM
  #10292
BACKintheDA's Avatar
Default Re: (Jose-aka-Pedro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb8thekid &raquo;</TD></TR><TR><TD CLASS="quote">one from work.
Size:  44.7 KB</TD></TR></TABLE>
OG's
Old Oct 14, 2006 | 02:47 PM
  #10293
Mattyg2's Avatar
can someone tell me why my fog fuse keeps blowing out? the fogs work for like 30 min then the fuse blows
Old Oct 14, 2006 | 02:57 PM
  #10294
Default Re: (Mattyg2)
Check the wiring and make sure the correct size fuse is being used.
I swapped out the stock 35w stanly for 55w SIlverstars and its still fine.
Old Oct 14, 2006 | 03:39 PM
  #10295
Mattyg2's Avatar
its correct, its the 10A fuse for the fog lights and i checked the wiring so many times and i have sylvania 55 watt bulbs in it. im stumped and mad that i cant show my cool yellow fogs lol
Old Oct 14, 2006 | 04:18 PM
  #10296
lol. Yeah I have the 55 silvertars,
Uh, I really dont know man. maybe a ground or short somewhere.
But if you checked your wires then there shouldnt be.
Not sure man post this up in the Integra forum.
I'm no help these days.
Old Oct 14, 2006 | 06:36 PM
  #10297
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PandaHatch &raquo;</TD></TR><TR><TD CLASS="quote">Wow have you met a kick in the *****? What you are trying to say absolutely makes no sense what so ever. Honestness, noun - the quality of being honest. Expand your vocabulary retard. Wow, highschool have I met you? ****** dumbass. </TD></TR></TABLE>
Shut your ******* mouth...you need to expand your mouth and stick your boyfriends dick in there.
dictionary.com says:
honesty
n 1: the quality of being honest [syn: honestness]
do you know what a synonym is?
fu ck yourself for getting bent out of shape so easily....******* civilians
Old Oct 14, 2006 | 07:26 PM
  #10298
Pacifier's Avatar
Default Re: (JasperDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasperDA9 &raquo;</TD></TR><TR><TD CLASS="quote">
honesty
fu ck yourself for getting bent out of shape so easily....******* civilians</TD></TR></TABLE>
Quit the ****** bitching already,you're going to ruin a perfectly good thread
And whats with the "******* civilians" comment?Like being in the armed forces makes you better than everyone else?******* elitist
Old Oct 14, 2006 | 07:52 PM
  #10299
k-series's Avatar
Thanks for serving our country, but don't knock yourself the fu ck out patting your own back.
Holier than thou attitude is horse ****.
Steve
Old Oct 14, 2006 | 08:29 PM
  #10300
Default Re: (k-series)
Bump.
Be mature and end this. I'm 17 and feel like I'm your moms
trying to break you guys up.
Back to the thread, like....
