d15z1 / d16y5 VTEC-E Squad!
Old Aug 2, 2011 | 11:58 AM
  #301
nickcrank's Avatar
Default Re: d15z1 / d16y5 VTEC-E Squad!
Originally Posted by snypez
is the y8 still running? from what i know about vtec-e you are probably running very lean up to the first vtec point then when you switch to the 4 valve map you are probably still a little lean (running a 'true' vtec cam when the ecu thinks its just in 4 valve) then when you switch to the final cams map in the ecu you finally are in the neighborhood, except that the whole time you have been running on undersized injectors. do you have a wideband (friend with wideband)?
yes it actually runs very well (i should put a vid up of me running at ams friday drags). the only problem i feel is that when it hits 2800 and goes into the second fuel map it kinda feels like a bog for a second and picks up with plenty of torque. with the new clutch and the torque of the y8 i can even chrip third for about almost a second and the y8 is fully stock. also im soon to have my turbo setup complete and start installing. and yes i do have wideband.
Old Aug 6, 2011 | 11:45 PM
  #302
hmong337's Avatar
Originally Posted by austinkli
Anybody ever seen vtec-e Decals?
I NEED THIS!!!
Somebody make it.
Old Feb 7, 2012 | 07:18 PM
  #303
dannydos's Avatar
Bump because I just bought a 97 civic HX.
Old Feb 13, 2012 | 03:06 PM
  #304
nickcrank's Avatar
Originally Posted by hmong337
I NEED THIS!!!
Somebody make it.
https://www.facebook.com/photo.php?f...type=3&theater
had a lady from ebay make a set for me, look for vtec decals and see if you can find someone simmilar
Old Feb 13, 2012 | 03:15 PM
  #305
nickcrank's Avatar
hope you love it! i couldnt imagine not having mine in this economy.
Old Feb 28, 2012 | 02:26 PM
  #306
selder's Avatar
now IS a good time!!
I always get 40 mpg or more from my '92 EH with a D15B8, so I'm really hopefull that a VTEC-E swap will be even better....
Old Apr 8, 2012 | 11:30 AM
  #307
EmZvr's Avatar
I want in too. I have a Civic MB3 made in UK with D15Z8 vtec-e with ECO mode. Mods so far:
D16Z6 intake manifold, no EGR
Integra air box
4-2-1 Twister exhaust manifold
Powerflow exhaust system, no cat, stock muffler
Fuel economy: around 48MPG
Old May 19, 2012 | 10:42 AM
  #308
Remix22's Avatar
do i qualify if i have an hx with a z6 head swap?
Old Jun 19, 2012 | 10:36 PM
  #309
ap1padawan's Avatar
BUMP THIS THING!!
I JUST BOUGHT A 94 VX ! White. If I drop it or put some Si rims then I'll put up pics. itll be sweet.
Old Jun 24, 2012 | 01:23 PM
  #310
bimmernut's Avatar
VX - vehicle extraordinare - I commute a minimum of 150 miles/day, so yeah,
the VX is awesome! Put me on the squad, por favor.
Old Jul 23, 2012 | 01:06 PM
  #311
Pandota757's Avatar
Ok i have a 97 honda civic with d16y5 and it dosent stay at a steady speed?
Old Sep 10, 2012 | 08:31 PM
  #312
nealnanoHX's Avatar
I was in the Vtec E club for about a year. I did love the 35-40 MPGs my 98 Hx got. I managed to run a 15.919 ET in it with just a CAI and an axle back exhaust. Now it has a LS Vtec swap in it.
Old Oct 19, 2012 | 12:41 PM
  #313
94EG6hatchy's Avatar
I WOULD JOIN THIS
Old May 27, 2014 | 04:44 PM
  #314
HeXtacY5's Avatar
Is it too late for me to join the D16Y5 squad?
Old Jul 15, 2014 | 03:50 PM
  #315
Bense's Avatar
Viva La VTEC-E!
Old Jul 19, 2014 | 05:29 PM
  #316
dmncj's Avatar
Hey, hey, hey,
Can I be added to the VTEC-E squad, I have a 1997 HX coupe, (probably the only one in Bahrain) and have a lot of time on my hands and am really researching this modification with my y5 cylinder head on a y8 block. Still reading through threads upon threads. (Good stuff) Thanks everyone for the info.
Old Feb 4, 2019 | 10:14 AM
  #317
MauricesExoticP's Avatar
Lots of haters seem to jump in and give their opinions here, I just started working on my basic plan for my 92 VX.
01 PMS-A00 0.25 over pistons and rings
D16Y8 head with the Z1 valvetrain swapped over
D16Y8 intake manifold with a D16Z6 throttle body
A good header
AEM electronics perhaps even so far as a distributor delete COP modification
ACT rigid clutch and ACT light weight flywheel
Possibly a Si brake upgrade
11:1 static compression
E85 fuel
Adding front and rear anti roll bars, as well as eibach multi pro r2 coilovers, power steering and a few other basic creature comforts like cruise control and power windows
Looking for this to be a fun daily driver not a huge power build. I'm guessing 170hp max.
Old Feb 8, 2019 | 02:04 AM
  #318
Bense's Avatar
A good header
E85 fuel
Why not just use the HX head? D16y8 and D16y5 heads are the exact same part number.
Old Feb 12, 2019 | 04:58 AM
  #319
I have neither the Y5 or Y8 heads so my main reason would be a Y8 complete head and intake manifold are in the plan.
I have nothing against using the HX cylinder head at all, if they are the exact same casting and part number there really is no functional difference between the two.
The HX intake manifold is not what I'm looking for in this build at all. While the HX manifold looks similar to the Y8 manifold I am not interested in the EGR portion of it.
Maurice
Old Feb 16, 2019 | 08:25 PM
  #320
pooby1992's Avatar
My still mostly stock '92 VX
https://i.imgur.com/xDzQqAJ.jpg
https://imgur.com/xDzQqAJ
Old Feb 15, 2021 | 05:10 AM
  #321
Hookemup's Avatar
I have a 92 vx with a d15z1 really new to the Honda world and just wondering what I can do for mods any help would be great will post pics today
Old Feb 15, 2021 | 02:35 PM
  #322
Bense's Avatar
Send @BauleyCivic a message and ask him
Old Feb 19, 2021 | 09:31 AM
  #323
BauleyCivic's Avatar
Risky Business
Leave it stock and sell it for $15,000 on bringatrailer in 5 years.
https://bringatrailer.com/listing/19...i-hatchback-2/
Old Sep 27, 2021 | 01:50 PM
  #324
93 vx that is mostly stock at the moment...including the ugly teal paint.
I'm interested in the Z1 cam specs, mostly the duration and ramp rates (I think I've got access to the lift numbers but have not verified so don't want to add incorrect info to the net), if anyone has the info in any format that would be great. My understanding is the intake side max lift is actually higher than the Z6/Y8 I've been unable to find duration numbers for either the intake or exhaust lobes.
My plan is a bit out of the norm;
I have a large rod journal D15B crank to replace my small journal Z1 crank.
I'm going to use vitara spec long rods, 0.5mm over D17 pistons with the tops milled to zero deck on my appropriately machined Z1 block. This piston milling will be in the realm of 0.889mm +whatever is needed to true up the block.
I'm not exactly getting much by way of interest from the cam grinders out there, except the "stupid idea is stupid" type stuff that pretty much let's you know those aren't the folk you want to work with.
My thought is I can chunk out the math and figure out valve relief cuts on the pistons if needed or not.
A little GT2554R based turbo system will add all the pep I'll want in the canyons around my home.
D16Y8 rocker cover
VTEC-E rocker cover
D15Z1 intake manifold, tiny little thing
I'll take the 666th spot, 69th spot, or both.
Yeah, I dug this up from the depths of thread oblivion, and even added a little useful content.
Old Oct 6, 2021 | 05:35 AM
  #325
Bense's Avatar
I've got threads where I've written about almost exactly what you're describing. Its an interesting project. I wound up going another route.
I'm at a point in my life, career where I cannot allow myself to venture off into academic projects such as VTEC-E. I am able to continue to pursue my passion with building Honda transmissions because I'm doing stuff for J-series / FK8 Type R. There's pretty much zero possibility of being able to earn money working on Hondas by developing parts / pursuing engineering projects that would cater to the fuel efficiency crowd. You'd end up doing more work, making less money.
