___||SOHC Squad||___
Old Dec 18, 2009 | 07:43 AM
  #1276
EJ6-2nr's Avatar
Default Re: ___||SOHC Squad||___
I gotta carry out my plans for the coupe before she'll let me get something else haha
i think next will be an eg hatch or ls teg, i cant make up my mind
Old Dec 18, 2009 | 07:49 AM
  #1277
jhammond_82's Avatar
Reject Papi
i'm leaning more towards an eg also. another sedan would be nice.
Old Dec 18, 2009 | 07:58 AM
  #1278
EJ6-2nr's Avatar
i'll be parting on out the 97 sedan this spring if anyone is interested PM me, squad members will get first dibs and hella cheap prices
Old Dec 18, 2009 | 08:21 AM
  #1279
C_R_X_V_T_E_C's Avatar
what up squad? just got off work...
Old Dec 18, 2009 | 09:04 AM
  #1280
nayumi0818's Avatar
Originally Posted by matt j
how much money are you wanting to spend on the clutch and flywheel setup? i would say do a nice setup the first time so that way you dont have to do it again later down the road, what kind of plans do you have for the car? boost or stay n/a?
just wanna stay n/a and its my dailly
Old Dec 18, 2009 | 09:36 AM
  #1281
EJ6-2nr's Avatar
so i've got this weird creaking noise coming from the front suspension, hear it when I turn the wheel slightly to the left or right from strait, doesnt matter if im in motion or parked. also makes this same noise when u push down on the fender or get in and out of the car, any ideas? axles look good, steering rack is dry and all the tie rod ends are new...
Old Dec 18, 2009 | 09:50 AM
  #1282
nayumi0818's Avatar
To mr mattj... I want to go with the sugestion you gave me on page 42... With the cam and the vafc etc...
Old Dec 18, 2009 | 09:53 AM
  #1283
superdave80's Avatar
New User
can anyone show me some dyno on turbo sohc
Old Dec 18, 2009 | 10:21 AM
  #1284
matt j's Avatar
Sounds like its your bushings squeaking, need to be oiled or greased or replaced.
Alright you could go with the act stock street disc, with the modified street pressure plate and a 8lb fidanza flywheel
part number for clutch kit- HC5-SPSS
part number for flywheel- 191161
That clutch holds up to about 186 ft-lbs of torque, so it will hold what you are going to have done to the car, and still have a pretty stock feel on the clutch pedal but have a faster engagement over stock. The flywheel will help lessen the rotating mass of the bottom end and give you a bit better acceleration over stock, not saying its going to be supa fast but it will be better
Old Dec 18, 2009 | 10:27 AM
  #1285
EJ6-2nr's Avatar
We just lubed everything and its still there, but I think we've narrowed it down to a defective lower bj that i just had replaced a couple months ago
how hard is it to replace the lower bj? i can get the part warrantied but i really cant afford to have a shop replace it again and so i would like to do this myself but if it requires a lift or any special tools then im sol...
Old Dec 18, 2009 | 10:53 AM
  #1286
matt j's Avatar
well the big portion of the labor is having to pull the hub assembly to press out the lower ball joint, so easiest and cheapest thing to do would be to pull the hub assembly, take it into a shop press out the ball joint, then press in the new one, then reinstall the hub assembly
Old Dec 18, 2009 | 10:57 AM
  #1287
EJ6-2nr's Avatar
oh ok thanks, well for what they charge to do that I might as well just drop the car off and have em do the whole job, not happy about it but im gonna get warranty on the part and then im going after the manufacturer of the part for a labor warranty. thanks for your insight guys you've been a big help
Old Dec 18, 2009 | 11:05 AM
  #1288
matt j's Avatar
pulling the hub really isnt that hard, its 4 bolts total, its really easy, im doing that to my sedan today putting on the new integra hubs. you just take off the upper ball joint bolt, lower ball joint bolt and the tie rod end bolt, then pull the bolt for the brake line and pull it out.
Old Dec 18, 2009 | 11:25 AM
  #1289
lethal_si's Avatar
wats good errbody!!! been hella sick.. like i got swine!!! ahaha but yea boutta go pull my motor out tday!! post pics up later!
Old Dec 18, 2009 | 11:32 AM
  #1290
matt j's Avatar
im getting ready to go pick up my son from school and bring my little helpers (all 4 of my kids) to go work on the sedan, swapping out both front hubs and also swapping from 13in steelies to 15in rota gt3s, and tossing in my jvc cd player from the coupe for now so i have some music lol, will post up pics when i bring it home!
Old Dec 18, 2009 | 12:04 PM
  #1291
chuckles_eg's Avatar
Can I join?
General run down: My name is Chuck, I'm from Cincinnati, I drive a 94 civic ex. 5 speed. tucked y8, megnaflow exhaust, no name header, lowered on Eibach springs, HID 10k's, short shifter amd a few other misc things.
The pix I inclded were before my tire blew and messed my car up. I will be getting my car fixed new month along with alot of other upgrades(i'll tell what all those are in a minute)
Current State:
Before the tuck:
After:
As soon a s I get me income tax back I will be giving the car a complete makeover:
1.Either Konig Retrack, Enkei FN-18, or Rota Track-R rims. Which ever I decide will be 15" white with machined lip
2.New front bumper, passenger fender, and passenger mirror.
3.Jdm thin side moldings
4.Window visors
5.Rear window visor
6.Sunroof visor
7.M3 stlye trunk lip
8.Buddy club lip kit
9.Amber side markers
10.Vision Amber corners
11.Windows Tinted lightly
12.Extended Lug nuts, probably Blox new burnt purple color ones
13.Jdm Audio console
14.Both rear quarter panels redone to get rid of the rust
15.Amber knock off Jdm fogs
16. Nice set of coilovers with struts, I want a lower stance but not super bouncy so I'll probably get Skunk2
17. Blox read lca's
18.Tow hook. (haven't decided if I want one for front or rear)
19. Weld in all old bolt holes in the bay and shave it/respray it
20. Respray the whole car same purple
21. Clear transparent hood
Like I said, all of this should be done by late Feb. It could very well be done earlier because I have already found where Im going to buy everything from, its jsut a matter of getting everything done in a timely manner but not rushing and possibly having crappy quality installation.
Old Dec 18, 2009 | 12:31 PM
  #1292
nayumi0818's Avatar
Thank you so much for the information matt... Ill order the parts asap... But first nedd to buy gifts for my family and my girlfriend and my 3 yr old baby...
Thank you so much...
Old Dec 18, 2009 | 01:04 PM
  #1293
marquisdee1018's Avatar
Which bushings make that noise? Mine is doing the same thing.
Old Dec 18, 2009 | 01:54 PM
  #1294
nayumi0818's Avatar
where do you live in vallejo mr lethal_si?
i wanna watch you pull the motor...
text me 707-853-3853
Old Dec 18, 2009 | 02:20 PM
  #1295
matt j's Avatar
there are some rubber bushings between the springs that i have found make that noise, the top hat bushings could, and then it could be ball joints as well
Old Dec 18, 2009 | 02:22 PM
  #1296
matt j's Avatar
heres some pics of the new sedan!
and the almighty D!
Old Dec 18, 2009 | 03:57 PM
  #1297
prelude182's Avatar
What brand is your clutch and flywheel? How many lbs?
I was rockin a competition clutch. I was satisfied with it. Im gonna get another one once I get the funds to do so.
and the almighty D!
damn that thing is FILTHY!!! Good thing its only a DD.
Old Dec 18, 2009 | 05:10 PM
  #1298
single cam fan's Avatar
Originally Posted by chuckles_eg
Can I join?
Current State:
Before the tuck:
After:
4.Window visors
5.Rear window visor
6.Sunroof visor
17. Blox read lca's
clean car, nice tuckage action
Old Dec 18, 2009 | 06:09 PM
  #1299
fre's Avatar
fre
Can I join?
Current State:
Be active in the thread and we'll see what happens. Currently it takes a month for enrollment but other then that....WELCOME!!!
Originally Posted by 4g4dcruisin
RULES
-Must have either SOHC D, F or ZC series motor, NA or boosted.
-Must have some sort of modification to their car, i.e. drop, swap, paint...things like that.
-Must be active for at least 1 month before joining the squad.
-If unactive for a lengthy period of time, you will be removed from the front page.
-Post pics of your ride with specs.
-No hating on someones ride.
-Keep it civil and help each other out!
Old Dec 18, 2009 | 06:12 PM
  #1300
prelude182's Avatar
I dont think ill be single slammin for very much longer guys.... My buddy is buyin an engine tommorow and were gonna boost it, meanwhile hes givin me his b18 Ls motor.
