TIAL, TIAL, TIAL, TIAL Wastegates, Blow off Valves, Flanges !!!!!!
<FONT SIZE="4"> http://www.IPGParts.com </FONT>
we are your one stop shop for all your Tial Wastegate, BOV, and Flange needs:
<U>PM, Email Sales@IPGParts.com, or call 407-324-4684 for inquries</U>
Toll Free Order Only Line - 877-629-9679
We accept all major credit cards, paypal, or money orders for payment.
Tial Specifications:
- 347 Stainless Steel Alloy is used for valve and valve housing.
- High temperature silicone Nomex reinforced actuator diaphragm.
- 17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resists "relaxing" at temperature to 900F (483C).
- Nitronic 60 Stainless Steel is used for the valve seat, and valve bushing the same material used in the higher level gates for reliability and longevity.
- CNC Machined 304L 12mm thick weld flanges.
- Low Cost.
- Made is USA.
- Color anodized 6061-T651 aluminum actuator (Silver, Red, Blue, Purple, Black).
- Wastegates shipped with air fittings and stainless hardware.
- Flanges are an extra cost, they do not come with the wastegate unit.
Available Colors:
Silver
Black
Red
Blue
Purple
Tial 38mm Wastegate:
Included with every Tial 38mm:
WG 38mm Assembly
38mm Valve Seat
2 Gaskets
2 TiAL Air Fittings
2 Mounting Bolts
4 Flex Washers
Tial 44mm Wastegate:
Included with every Tial 40mm:
WG 40mm Assembly
40mm Valve Seat
4 Stainless Steel Studs w/ Nuts.
4 Stainless Steel Bolts
4 Large + 4 Small Flex Washers
2 TiAL Air Fittings
Included with every Tial 44mm:
WG 44mm Assembly
44mm Valve Seat
Inlet V-band clamp
Inlet Flange
Outlet V-Band Clamp
Outlet Flange
2 TiAL Air Fittings
Tial 46mm Wastegate:
Included with every Tial 46mm:
WG 46mm Assembly
46mm Valve Seat
8 Stainless Steel Bolts
2 TiAL Air Fittings
2 Gaskets
Tial 50mm Blow Off Valves:
TiAL's high performance Blow off valve. Tailored to your specific application. Handling 80+ Psi, dependable in the most extreme environments.
Modified by Innes at 8:22 AM 5/26/2007
Modified by Innes at 11:11 AM 5/30/2007
Modified by Innes at 7:08 PM 6/13/2007
- Low Cost.
- Made is USA.
Available Colors:
Silver
Black
Red
Blue
Purple
WG 38mm Assembly
38mm Valve Seat
2 Gaskets
2 TiAL Air Fittings
2 Mounting Bolts
4 Flex Washers
WG 40mm Assembly
40mm Valve Seat
2 TiAL Air Fittings
WG 44mm Assembly
44mm Valve Seat
Inlet V-band clamp
Inlet Flange
Outlet V-Band Clamp
Outlet Flange
2 TiAL Air Fittings
WG 46mm Assembly
46mm Valve Seat
2 TiAL Air Fittings
2 Gaskets
Re: TIAL, TIAL, TIAL, TIAL Wastegates, Blow off Valves, Flanges !!!!!! (MazworxRaceSupply)
just launched...
.... http://www.MazworxRaceSupply.com
James the new site looks great! Nice meeting ya the other day sorry I couldnt stay and bullshit I had to get back and finish some stuff up... maybe another time!
