Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Synapse Synchronic FPR/FMU - Wholesale - FREE Ship!
Old 01-24-2006, 01:40 PM
turbo-kits-com's Avatar
Default Synapse Synchronic FPR/FMU & Missing Link Package - Wholesale!
Retail is $219 for the FPR/FMU & $65.00 for the Missing Link. Our Package Prices blow those away.
We can also do just the FPR/FMU for anyone interested. Still good prices
PM for more info...
Here are some of the main points with this FPR:
*Absolutely no diaphragm, eliminates the use of diaphragms altogether
*Use as 1:1 for all motor, or 12:1 for starter turbo kit, or pure 1:1 for EMS, Uberdata, Hondata, etc.
*Adjustable static fuel pressure
*Interchangeable bypass fittings to adjust for different flow fuel pumps
*Rising rate ratio is infinitely adjustable between 1:1 and 12:1
*Designed to take a direct injection of Nitrous, so you can raise fuel pressure for a dry system
*Smaller in major diameter than AEM FPR for size references
*Bolts straight onto OEM and aftermarket fuel rails
*One part # will fit all Honda models
Here's the installation and tuning manual in case you guys need more detail http://www.synapseengineering....l.pdf
jesse@turbo-kits.com
PH: 860-676-2929
Modified by turbo-kits-com at 12:22 PM 1/26/2006
Old 01-24-2006, 02:44 PM
integra3586's Avatar
Default Re: Synapse Synchronic FPR/FMU & Missing Link Package - Wholesale! (turbo-kits-com)
pm'ed
Old 01-24-2006, 03:52 PM
iakona's Avatar
you got PM sir...
Old 01-24-2006, 04:34 PM
Default Re: (iakona)
All PMs replied
Thanks
Jesse
Old 01-25-2006, 10:33 AM
Default Re: (turbo-kits-com)
ttt
Old 01-25-2006, 03:56 PM
just placed order awesome deal guys
Old 01-26-2006, 04:56 AM
urname7698's Avatar
pm'd
Old 01-26-2006, 07:54 AM
Default Re: (urname7698)
PMs Replied...
http://www.turbo-kits.com
860-676-2929
Old 01-26-2006, 11:23 AM
We can just do the Synapse Synchronic FPR/FMU for anyone interested and you will still get a slamming deal
860-676-2929
Old 01-26-2006, 07:08 PM
bump for awesome deal
Old 01-27-2006, 09:48 AM
Default Re: Synapse Synchronic FPR/FMU & Missing Link Package - Wholesale! (integra3586)
All PM's replied tooo..
Thanks for the props
860-676-2929
Old 01-30-2006, 08:11 AM
All PM's Replied
860-676-2929
Old 01-30-2006, 02:10 PM
We're doing orders 10 at a time and we are almost there. Remember you can buy just the FMU/FPR is you do not want the package
860-676-2929
Old 01-31-2006, 04:21 AM
iakona's Avatar
up. for an awesome piece. and a great deal!!
Old 01-31-2006, 07:32 AM
PM's replied... Almost ready to place the first order
860-676-2929
Old 01-31-2006, 03:48 PM
Pm Replied too
860-676-2929
Old 02-01-2006, 05:21 AM
iakona's Avatar
money sent. i'm in!
Old 02-01-2006, 06:42 AM
Thanks for the orders...
860-676-2929
Old 02-02-2006, 09:00 AM
All PM's Replied
860-676-2929
Old 02-03-2006, 05:12 PM
bob95egdx's Avatar
I'm a little confused about fuel pressure regulators. What happens to the fuel pressure when my car is making 8 lbs of boost with the stock FPR? I have been thinking it stays at 42 psi since I don't have an FMU. I use uberdata and 450 dsm's. I just bought a walbro fuel pump because I plan on upgrading with a built engine to run a lot more boost with 750cc injectors and maybe switch to Crome pro for tuning. I also have a B+M fpr that I haven't installed yet but I heard that the B+M won't be able to turn the the fuel pressure back down from the new pump and it will be like 50psi unless I drill out some orifice in the fpr.
Old 02-06-2006, 06:51 AM
Default Re: Synapse Synchronic FPR/FMU & Missing Link Package - Wholesale! (bob95egdx)
The Synapse is a 1:1 up to a 12:1 FPR/FMU.... If you already have an ECU that can adjust the fuel maps based on boost then you do not need to run more than 1:1 FPR. In that case, the benefits of this unit are the piston set up. It uses a piston to control the fuel pressure so you don't have issue with the heat sink causing the diaphragm to loosen up (see above pics). Therefore, it will keep a consistent fuel pressure from the 1st run to the last. This unit also uses 3 different fuel return settings that allow you to run a larger orifice when running a high pressure fuel pump so that you can actually adjust the pressure back down to the 42PSI stock level. The issue you are talking about with the B & M or AEM FPRs w/ a Walbro, BK or other high flow pump.
Synapse actually suggests running 2:1 or even 3:1 under boost to help with fuel dispersion. Think of it as turning on the hose in the wind, if you just let the hose run, the wind will blow the water all over, but if you put your thumb on it, you will up the pressure and create a spray pattern that cuts through the wind better. Same goes for upping the fuel pressure under boost. It also lets you flow more fuel through the same size injector making lumpy idle a thing of the past
Hopefully this helps, let me know if you have any further questions, and def ask them on the forum so that the answers can educate all looking for the info
860-676-2929
P.S. All PMs Replied to
Old 02-08-2006, 06:22 AM
The first order fo ten will be at my door by the end of this week. I will have all orders shipped by early next week. We still have some left from the first 10. Please contact us ASAP! to get in on this first shipment
860-676-2929
Old 02-08-2006, 01:25 PM
ttt
Old 02-14-2006, 02:22 AM
can i get a tracking number?
Old 02-14-2006, 10:19 AM
acydphryck's Avatar
free bump for nice product
Quick Reply: Synapse Synchronic FPR/FMU - Wholesale - FREE Ship!
