SpeedFactory Racing 3, 4, and 7 Bar Map Sensors $90 Shipped!!!
Our Speedfactory 4 Bar MAP sensors use state of the art bipolar op amp circuitry with thin film resistor networks built into each micro chip. Pressure changes are calculated on a true linear 0-5 volt scale via a specially designed silicon pressure sensor that also compensates for temperature changes. The unique ability to compensate for temperature changes allows our MAP sensor to remain a minimum of 99% accurate from 32 degrees F to 180 degrees F through out its range of scale. With the true linear pressure vs. voltage scale there is never a need to re-tune at different altitudes as with other sensors. Speedfactory 4 bar MAP sensors can precisely calculate boost pressure from 1-43+ psi while still allowing smooth stock OEM drivability at any boost level. Conveniently packaged in an OEM dimensional housing for easy install and an OEM look.
Our MAP sensors are manufactured in the USA!!! Lifetime Warranty!!!
Key features:
* 40 to 260 degrees Fahrenheit temperature operating range
* Able to respond from 10% of the pressure scale to 90% of the pressure scale in .001 seconds (the fastest response time of any MAP sensor on the market).
* Automatic temperature compensation.
* True linear scaling for perfect drivability at all boost and vacuum levels.
* Compatible with all aftermarket engine management systems.
* Minimum of 99% accurate over full scale range under all conditions including temperature, altitude, and humidity changes.
* Allows smoother engine operation, higher boost levels, and better drivability than competitors turbo MAP sensors.
* Direct plug and play for an easy install and an OEM look. Dimensionally identical to the stock MAP sensor.
* Each sensor is hand assembled, pressure, and function checked in the USA for unparalleled quality control prior to shipping
Introductory HT Member Pricing $90 Shipped! Click here to purchase http://www.speedfactoryracing.net/st...roduct=7904394
Our MAP sensors will fit:
94-01 Acura Integra
90-93 Acura Integra (will require 94-01 Integra Throttle Body)
97-99 Acura CL All Models
01-03 Acura CL V6 (premium only)
99-03 Acura TL All Models
88-00 Honda Civic All Models
92-01 Honda Prelude All Models
00-05 Honda S2000 All Models
94-02 Honda Accord All Models
93-97 Honda Del Sol All Models
Re: SpeedFactory Racing 3, 4, and 7 Bar Map Sensors $90 Shipped!!!
You can call the shop 253-566-4331 anytime or we accept Paypal speedfactorymh@gmail.com is the account name. PM me if you have any specific questions. Thanks
Matt
Matt
