Special Sale...Tial Wastegates
Logicmotorsports special sale on our current inventory of Tial Wastegates
Do You Want to Protect Your Motor from Blowing? Need an affordable Option to Regulate Your Boost Levels that is Reliable unlike cheap Ebay Knockoffs?
Look No Further...Logic Has the Solution
Without a way to regulate boost levels the turbo would keep producing higher pressures until the engine exploded. This is where Tial wastegates come in. Tial wastegates attach onto your turbo header. As you accelerate, exhaust gas pressure build inside the manifold and forced through the turbo. This pressure continues to increase as the turbo spins faster. When the desired boost level is reached, the wastegate opens and vents pressure from inside the manifold so the turbo won't spin any faster.
Description
TiAL's line up of high performance, race proven Wastegates. TiALs Wastegates are trusted by the biggest names in the racing industry. With so much depending on the performance of the valve, its no mystery team leaders choose to equip their cars with the best.
Tial MVS Wastegate:
Included with every Tial MV-S:
MV-S Assembly
2 TiAL -4 removable water fittings
MV-S Valve Seat
Inlet V-band clamp
Inlet Flange
Outlet V-Band Clamp
Outlet Flange
2 TiAL Air Fittings
Plugs for unused air ports
Extra actuator springs
Colors available:
Silver
Black
Red
Blue
Purple
Tial MVR Wastegate:
Included with every Tial MV-R
MV-R Assembly
MV-R Valve Seat
Inlet V-band clamp
Inlet Flange
Outlet V-Band Clamp
Outlet Flange
2 TiAL Air Fittings
Colors available:
Silver
Black
Red
Blue
Purple
Tial F38 Wastegate
Included with every Tial F38:
F38 Assembly
F38 Valve Seat
2 Gaskets
2 TiAL Air Fittings
2 Mounting Bolts
4 Flex Washers
Colors available:
Silver
Black
Red
Blue
Purple
Tial F41 Wastegate
Included with every Tial F41 Wastegate:
F41 Assembly
41mm Valve Seat
8 Stainless Steel Cap Screws.
8 Stainless Steel flex washers
2 TiAL Air Fitting
Colors available:
Silver
Black
Red
Blue
Purple
--------------PM FOR LOWEST PRICES--------------------------
Free shipping to the lower 48 states.
There will be an additional shipping fee to HI/PR/AK/VI/GU. Also, we will ship internationally for an additional shipping fee. If you are making a purchase from any of these areas, please contact us.
Check us out at www.logicmotorsports.com
Follow us at www.facebook.com/logicmotors
Description
Tial MVS Wastegate:
MV-S Assembly
MV-S Valve Seat
Inlet V-band clamp
Inlet Flange
Outlet V-Band Clamp
Outlet Flange
2 TiAL Air Fittings
Colors available:
Silver
Black
Red
Blue
Purple
Tial MVR Wastegate:
MV-R Assembly
MV-R Valve Seat
Inlet V-band clamp
Inlet Flange
Outlet V-Band Clamp
Outlet Flange
2 TiAL Air Fittings
Colors available:
Silver
Black
Red
Blue
Purple
Tial F38 Wastegate
F38 Assembly
F38 Valve Seat
2 Gaskets
2 TiAL Air Fittings
2 Mounting Bolts
4 Flex Washers
Colors available:
Silver
Black
Red
Blue
Purple
Tial F41 Wastegate
F41 Assembly
41mm Valve Seat
2 TiAL Air Fitting
Colors available:
Silver
Black
Red
Blue
Purple
