Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Race Engineering Block Guards and SUPER thick Cometic Headgasket
Old Aug 20, 2004 | 02:06 PM
prostreetonline's Avatar
Default Race Engineering Block Guards and SUPER thick Cometic Headgasket
We just got the largest Cometic Headgasket available by cometic (they just released it!). it's supposed to drop your compression on your GSR by about 2 POINTS!
Check out the pictures. We are also installing a Race Engineering Block guard. We plan to run 14psi on the stock GSR motor. This is going on our project GSR which can be found here:
https://honda-tech.com/zerothread?id=957889
If anyone wants these, we have them available, but they will be special order. We can usually get them in about a week. The headgasket would be $199.99, and the Race Engineering Block Guard is $144.99
Old Aug 21, 2004 | 08:14 AM
Tchleung's Avatar
Do you have Cometic gaskets for different applications?
Old Aug 21, 2004 | 09:35 AM
We can get them. We removed them initially due to Cometic's poor deliverability, but we can get whatever you like.
What do you need?
Old Aug 21, 2004 | 10:28 AM
Tchleung's Avatar
Default Re: (prostreetonline)
B16A
Stock 81 Bore
Prolly around .056" thickness or around there...
Modified by Tchleung at 9:12 AM 8/23/2004
Old Aug 23, 2004 | 08:12 AM
Tchleung's Avatar
Default Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">B16A
Stock 81 Bore
TTT
Old Aug 23, 2004 | 01:24 PM
ATF Kuk's Avatar
does cometic make a head gasket for the S2000? if so, how much shipped to 91780
Old Aug 23, 2004 | 09:53 PM
They do. Email me at alex@prostreetonline.com and I can get you some prices.
We're re-adding Cometic into our catalog since we are going to stock them now.
Thanks!
allmotorb20vtec
May 24, 2005 10:52 PM
prostreetonline
Aug 22, 2004 09:41 AM
DaveF
Jan 22, 2004 08:13 AM
