Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Profec B-SPEC2
Old Feb 7, 2006 | 03:12 PM
Cprace1's Avatar
Default Profec B-SPEC2
$310.00
Profec B-SPEC2
Based on the very popular B-Spec., the all new PRofec B-Spec. II's basic function to increase boost is as easy as the original, with an added built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI). There are optional warning and boost limiter functions that can be programmed to offer much more control. The two presets values can be stored and are executed by a larger capacity inline solenoid valve. This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbos with actuator or external wastegates. The GReddy PRofec B-Spec. II is available in black or silver cased head units.
Old Feb 8, 2006 | 12:36 PM
Cprace1's Avatar
Default Re: Profec B-SPEC2 (Cprace1)
bump!!
Old Feb 9, 2006 | 02:12 PM
Cprace1's Avatar
bump
Old Feb 10, 2006 | 06:52 AM
Cprace1's Avatar
bump!!
Old Feb 13, 2006 | 08:30 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Can you use the Greddy remote switch with the Spec-II model?
Old Feb 14, 2006 | 02:19 PM
Cprace1's Avatar
Default Re: Profec B-SPEC2 (boostincoupe)
you sure can
Old Feb 15, 2006 | 03:02 PM
Cprace1's Avatar
bump!!
Old Feb 17, 2006 | 12:32 AM
sohctodohc's Avatar
would this work with the greddy kit with the internal wastegate?
Old Feb 22, 2006 | 02:03 PM
Cprace1's Avatar
Default Re: Profec B-SPEC2 (sohctodohc)
yeah it will
dcmodnight
Northern California (Sales)
Jul 7, 2012 07:45 AM
effin
Nov 22, 2009 04:19 AM
Drkaccrd
Jun 7, 2005 09:28 PM
phiberoptik
Jul 24, 2003 09:15 PM
Accord94DX
Apr 2, 2003 06:03 AM
