Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Injector Dynamics ID2000 injectors are here!!
Old Sep 3, 2009 | 07:51 AM
tony1's Avatar
Default Injector Dynamics ID2000 injectors are here!!
Finally, a great solution for people that need more than 1500cc/min!!
The new Injector Dynamics ID2000 flows 2200cc/min at 3 bar (43.5psi) and is high impedance.That means no injector resistor or injector driver is needed.With the capability of running up to 130psi and flowing 3700cc/min, the needs for running multiple injectors per cylinder are gone on all but the most demanding methanol applications. Each injector includes the necessary adaptor top and electrical connector.The adaptor tops mechanically lock to the injector and also incorporate a 7 micron replaceable filter.
With the most linear flow in it’s class, great atomization and full injector dead time information provided, there really is no competition for the ID2000.Check out this video to see how well they run in a worst case scenario, a bone stock 120hp car!
Visit http://www.injectordynamics.com/ID2000.html for more information.
Old Sep 16, 2009 | 09:25 AM
espanol's Avatar
Default Re: Injector Dynamics ID2000 injectors are here!!
Old Oct 20, 2009 | 05:22 AM
espanol's Avatar
Originally Posted by espanol
Old Nov 6, 2009 | 01:28 PM
espanol's Avatar
Check out the new site: www.T1RaceDevelopment.com
Old Nov 11, 2009 | 12:59 PM
espanol's Avatar
TTT
Old Nov 19, 2009 | 08:39 AM
espanol's Avatar
TTT
Old Nov 25, 2009 | 06:09 AM
Antilag's Avatar
Looks good Tony! How well are these with q16?
Old Nov 25, 2009 | 07:37 AM
tony1's Avatar
These are not compatible with Q16 or VP Import. There is a chemical in those fuels that restricts flow with the ID2000. We recommend VP C16 or C23 fuel for the ID2000's. I'm running the 2000's with C23 on my car.
Old Nov 29, 2009 | 05:47 PM
harhoosh's Avatar
I am using right now ID1000 with twin walbro intank, i set the base pressure at 50psi and i max them out at 715whp.
since i cant increase the base pressure any more with the walbro, do you think the ID2000 will be good for me or i have to change the pumps to twin bosch and increase the base to 100psi?
now i am looking for 800+ whp.
Old Nov 29, 2009 | 05:54 PM
tony1's Avatar
The ID2000's are definitely a better option for you.
Old Nov 29, 2009 | 06:40 PM
guy_from_nerk's Avatar
1000 bucks for a set of injectors...yikes!!
Old Nov 29, 2009 | 06:43 PM
Casey's Avatar
shut the **** up. these arent for back yard builds
Old Nov 29, 2009 | 07:00 PM
I wasn't being a dick ****face. I was simply stating that 1000bucks for a set of injectors is insane. I have actually bought parts off Tony in the past so blow me.
OP GLWS!
Old Dec 5, 2009 | 09:16 PM
1fastacvw's Avatar
man, to bad i didnt wait a few months more i would of purchased these instead of the id1000's. the id1000s work bitchin btw...
can you use meth or eth with these injectors? also, i dont use vp fuels but f&l .. do you know what the chemical is that messes up the injectors is/
do you have a flow chart like you do with the id1000's
ty
dean
Old Dec 8, 2009 | 08:06 PM
tony1's Avatar
These are compatible with Methanol and Ethanol. Oxygenated fuels or those with MTBE are the ones to watch for that are not compatbile.
There is a flow chart on the ID website.
Old Dec 9, 2009 | 12:45 AM
noluckracing's Avatar
Do you need special fuel pump to use these injectors to run high fuel pressure and can you use S300 with them?
Old Dec 9, 2009 | 06:03 AM
tony1's Avatar
It's not likely that you'll need to run high pressure with these injectors. I'm making over 1000whp running 45psi base fuel pressure and i'm barely over 80% duty cycle.
You can use them with the S300.
boostedteg4dr
Nov 30, 2013 01:17 PM
kpjo4
Apr 15, 2010 10:15 AM
tony1
Performance
Sep 16, 2009 09:25 AM
HondaHeddie
Nov 26, 2008 10:44 AM
joeyitr309
Apr 22, 2005 08:07 AM
