EDELBROCK,SKUNK2,OMNI,Intake Manifold+Throttle Body Combo!LET THAT ENGINE BREATHE!!!
Hi, Logic Motorsports is now offering intake manifold and throttle body combos. Your choice from either a Skunk2 Pro series intake manifold or Edelbrock Victor X manifold, paired with a Skunk2 or Omni throttle body.
PM FOR BEST PRICING!!
ALSO ASK ABOUT FUEL RAILS AND INJECTORS!!
*Optimized for maximum power from 7,000 to 10,000 RPM, the Victor X manifold is designed for turbo and all-motor applications. Engineered for high performance, this manifold has four additional bosses for nitrous or added fuel injectors.*
*Skunk2’s Pro Series Intake Manifolds feature larger plenums and oversized runners when compared to OEM intake manifolds for maximum horsepower and torque gains. Instead of producing manifolds with significantly oversized plenums and excessively short runners that would sacrifice mid-range power, Pro Series manifolds were designed for the “street enthusiast” who wants more power but doesn’t want to sacrifice mid-range performance to get it. The results are improved airflow, an enhanced venturi effect, and both mid-range and top-end power gains. Skunk2 is a familiar name in the intake manifold business, with more than 10 years of experience designing, testing, and building them.*
*Skunk2 Throttle Bodies are designed to be used with factory intake manifolds as well as Skunk2’s Pro Series Intake Manifolds for bolt-on horsepower and torque gains by optimizing engine airflow. Skunk2’s Pro Series and Alpha Series Throttle Bodies are manufactured from the finest materials and feature significantly larger bores, which result in significant horsepower gains throughout the powerband on naturally aspirated applications and even more on forced induction ones.*
*Omni-Power Throttle Bodies are available in 68mm and 70mm and are designed as an OEM replacement product that bolts on without any modifications. You can expect increased throttle response and an increase in horsepower by simply bolting this product on to your car. Will fit all DOHC VTEC B Series motors*
Thanks,
Devin@Logic Motorsports
Thanks,
