COMPETITION CLUTCH STAGE 1-5,SUPER SINGLE,TWIN & TRIPLE DISC,FLYWHEELS,BLOWOUT SALE!!
Hi, making to much power for that stock clutch or just looking to upgrade your old worn out clutch? Logic Motorsports is proud to announce we are now having a BLOWOUT SALE on COMPETITION CLUTCH!! IN STOCK AND READY TO SHIP!!PLEASE PM ME FOR PRICING!!!
WHY DO YOU WANT A COMPETITION CLUTCH?
Competition Clutch (CCI) is the fastest growing performance clutch company in North America. CCI contributes this growth to its commitment in the innovation and quality of the products that we manufacture and supply, complimented by a sincere desire to provide unparalleled customer service and delivery.
Competition Clutch specializes in manufacturing sport compact assemblies from street driven to full race applications. You will find our products being proudly used in some of the fastest sport compact race cars in the country, including a number of the most recognized industry icon vehicles.
Competition Clutch brings to their customers the finest materials, workmanship, and the best customer service in the industry. We offer higher clamping force, stronger disc designs, and uncompromised satisfaction, all at the most competitive pricing in the industry.
STAGE 1- The economical solution for moderately modified cars or simply aggressive individuals with stock power. Offers up to 40-50% increase in torque capacity and maintains stock pedal feel. 300 mile break-in recommended with this set-up.
DO NOT use with added forced induction such as turbo, supercharger, or NOS systems.
STAGE 1.5- Competition Clutch Stage 1.5 (aka the Exedy Smoker) - designed from the ground up to smoke the competition. The Stage 1.5 offers an increase of 30% (up to 275lb/ft. torque) in clamping capability over the Exedy, it also offers excellent wear characteristics that easily meet or exceed the Exedy unit and it is priced at least 15% less. If you are looking for the best all around basic cluch to handle most basic bolt-on mods, this is IT, Competition Smokes the Competition!
STAGE 2- This assembly provides up to 80% increase in torque capacity and is properly suited for aggressive street use and moderate track use. The Brass Plus material with its alloy backing matched to a performance pressure plate will provide smooth engagement and extended life.
STAGE 3- This segmented Ceramic material with a performance pressure plate will provide the ultimate in street and strip combinations. This assembly is suited for up to 150% increase in torque capacity. Provides quick but smooth engagement and extended life.
STAGE 4 SPRUNG- This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides up to 250% increase in torque capacity.
STAGE 4 RIGID- This assembly, available with a six puck rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides up to 250% increase in torque capacity.
STAGE 5 SPRUNG- This assembly, available with a double spring, six rivet carriage is good for ease of gear transition with higher horsepower. This disc complimented by a performance pressure plate provides up to 300% increase in torque capacity.
STAGE 5 RIGID- This assembly, available with a rigid plate is good for penetrating engagement with higher horsepower applications. This disc complimented by a performance pressure plate provides up to 300% increase in torque capacity.
SUPER SINGLE- The Competition Clutch Super Single was developed for cars not quite ready for a twin but needing something more than the conventional Stage 4. The Super Single mirrors a twin disc in the fact that they both are a 7.25" set up and have a 4140 forged steel flywheel. Unlike the twin, the Super Single only uses one disc and tips the scales around 17-20lbs depending on application.
The Super Single is a must have piece for all-motor/nitrous cars running up to 450whp.
TWIN DISC- Competition Clutch provides the most economical racing clutch for the active sport compact enthusiast and is the preferred assembly for the professional racer. We currently offer our 4140 Forged Steel Flywheel with this unit to ensure durability in extreme racing conditions.
The CCI Twin Disc delivers uncompromised reliability and performance. All assemblies are plug and play with no additional modifications required in the transmission. Guaranteed to provide simplicity in installation and inexpensive component repair and replacement.
TRIPLE DISC- Competition Clutch provides the most economical racing clutch for the active sport compact enthusiast and is the preferred assembly for the professional racer. The CCI Triple Disc delivers uncompromised reliability and performance. All assemblies are plug and play with no additional modifications required in the transmission. Guaranteed to provide simplicity in installation and inexpensive component repair and replacement.
This clutch was designed to meet the needs of racers that are generating EXTREME power levels of 1100+HP. The addition of a 3rd disc and floater allows this clutch to handle even higher levels of torque & heat.
LIGHTWEIGHT STEEL FLYWHEEL- The ST flywheel is recommended for naturally aspirated and/or street driven applications.
This flywheel will work with ALL performance and stock clutch assemblies.
Qualities of the CCI Lightweight Steel Flywheel:
Preserves low end torque and drive ability
One piece ring gear for high durability
Weight varies from 11 lbs. to 25 lbs. depending on application
Well suited for Stage 1 and Stage 2 clutch kit applications
Stamped with 4140 plate with 2000 ton pressure at 1260 degrees
CNC machined and balanced to O.E. specifications
Reduced Mass = Increased Acceleration
Meets and exceeds SFI 1.5
ULTRALIGHT STEEL FLYWHEEL- The STU flywheel is recommended for forced induction and/or track and rally racing applications.
Qualities of the CCI Ultra Lightweight Steel Flywheel:
Weight varies from 8 lbs. to 18lbs. depending on application
Well suited for Stage 3 and up clutch kit applications
ALSO HAVE REPLACEMENT DISCS!!
DON'T FORGET TO CHECK OUT OUR WEBSITE!!http://www.logicmotorsports.com/
Thanks,
Devin@Logic Motorsports
Thanks,
