Avid Motor Swap Mount Kit
Avid Racing Motor Mounts making engine swaps in your Honda a piece of cake! Each mount kit is designed to be a direct bolt in for your Honda or Acura. These mounts are designed for B Series, H Series and K Series engine swaps.
<FONT COLOR="blue">AVID Racing Motor Mount Swap Kit</FONT>
Avid Racing Axles are made specifically for motor swaps with Honda and Acura vehicles. When doing a motor swap, sometimes using the wrong axle can cause the axle to pop out of the transmission, and cause all sorts of nasty problems. We recommend running the Avid Axles to prevent any problems. These axles are bolt in, and require no modification to fit.
<FONT COLOR="blue">AVID Racing Axle Swap Kit</FONT>
These Avid Racing shift linkage kits make engine swaps a breeze! Use these when swapping a different transmission into your car, usually when swapping a motor. These kits allow your shifter to be able to work with the new transmission. Direct bolt in, no cutting required.
<FONT COLOR="blue">AVID Racing Shift Linkage Kit</FONT>
Looking for more parts for your engine swap?
Click here: <FONT COLOR="blue">Avid Racing Motor Swap Kit</FONT>
Modified by prostreetonline at 5:03 PM 5/6/2007
RhdDc2R
Aug 4, 2006 03:38 AM
doublethink
15
Dec 5, 2004 12:27 AM
RS_H22
Nov 12, 2003 05:41 PM
