zex programming problems
Old Oct 10, 2008 | 09:28 PM
hondateg10's Avatar
From: Somewhere in the United States, united states
Default zex programming problems
like the title says. i just installed a zex wet kit on my EG hatch. i tried to follow the instructions but its not working.
the instructions says to turn key on the on position and then flip the arming switch. then go to the zex box and press the button light should go red after push the button. (the light for mine turns red as soon as i arm the switch) then push the throttle to full throttle for 10 sec then release. light should flash from red to green then off.(mine didnt do this)
can someone help me that has installed this kit
Old Oct 11, 2008 | 03:51 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: zex programming problems (hondateg10)
call zex on it, i had gotten 2 boxes a long time ago that wouldnt progran, that were bad. sent them back, they did something and they were all good.
Old Oct 11, 2008 | 07:31 AM
hondateg10's Avatar
can anyone tell me what wire im supposed to tap into on the TPS? i have 3 wires coming out of the TPS: red, green, yellow/green
Old Oct 11, 2008 | 10:03 AM
hondateg10's Avatar
found problem. i had it tapped into to wrong wire on the tps. the right wire is the middle red/black wire
schardbody
Mar 31, 2007 12:48 PM
Ignitecivic
Jan 5, 2006 12:07 PM
trevorclaus
Jul 4, 2004 05:05 AM
Officer
Apr 21, 2003 03:28 PM
dragonrcr
Sep 23, 2002 10:35 AM
