What kinda of blow down tube for a Zex bottle?
Re: What kinda of blow down tube for a Zex bottle? (tegunderpressure)
If you call Zex, they can get the right one. They have two bottle designs, internal thread and external thread. I think the tube and fitting cost me like $35 or so...directly from Zex.
If you are gunna be going to the track, it depends on how strict the tech inspectors are. & its a safety precaution. Safety first
New User
Re: What kinda of blow down tube for a Zex bottle? (c1hatch)
you only need a blown down tube if your bottle is in teh same compartment as the driver. I used an earls fitting and some braided line.
Theyre not strict at all. But what why do they have the restrictions? What kinda of safety does it provide? The only way it comes into use is if the bottle pressure becomes too high right? What situations can cause that?
gmoore
gmoore
New User
Re: (tegunderpressure)
You'll still want a bottle heater to give you consistent temperatures/pressures. If you don't have that then all of your tuning is useless. The blowdown tube is attached to a fittig that holds the burst disk. When the pressure gets too high the disk burst, releasing all of the nitrous into the atmosphere. The blowdown tube just directs the nitrous out of the car.
Re: (c1hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1hatch »</TD></TR><TR><TD CLASS="quote">actually, they was a webpage about a guy that left his bottle warmer on & literaly blew up his car & garage.</TD></TR></TABLE>
I saw that, scary stuff.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">Theres no way heat could cause that right? Those bottles are rated to 5000 psi arent they? And you average fill is what? 900 psi?
gmoore</TD></TR></TABLE>
i know the zex bottle warmer has 2 thermostats that turn off at a certain temp.
ive left my bottle heater on overnight more than once.
Re: (laughinxxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laughinxxx »</TD></TR><TR><TD CLASS="quote">You'll still want a bottle heater to give you consistent temperatures/pressures. If you don't have that then all of your tuning is useless. The blowdown tube is attached to a fittig that holds the burst disk. When the pressure gets too high the disk burst, releasing all of the nitrous into the atmosphere. The blowdown tube just directs the nitrous out of the car. </TD></TR></TABLE>
Ahh, never thought about that.
gmoore
gmoore
Tech inspect up here is strict. But usually you can just tell them there is no nitrous in the bottle and you're not going to be running it and they don't care. IMO blowdown isn't needed as long as you remember to turn the heater off. I mean, so what if you take a nitrous hit to the lungs. lol
