zeitronix wideband ecu codes
Old Jan 15, 2007 | 08:37 AM
wolve's Avatar
Default zeitronix wideband ecu codes
i've installed my zeitronix wideband/datalogging system needed for my little FI-project
now i'm throwing a code 15 and 41
41 i understand because of the new oxigensensor who gets its heater singal from the zeitronix-unit
code 15 is weirder, i needed to tap into a ignition output signal for the zeitronix, so i took it from the ecu. from pin 22
on the diagrams pin 22 is the same as pin 21
so i just pinned in an extra connector with the ingniter output (pin 22) connected to the zeitronix unit. should i splice into the igniteroutput signal from pin 21?
i hope someone has the same experience or same device and can tell me how to fix this.
engine is running fine btw
Old Jan 16, 2007 | 02:05 AM
wolve's Avatar
Default Re: zeitronix wideband ecu codes (wolve)
anyone running the zeitronix?
how did you wire the rpm signal and did you throw codes because of that?
mikeszutu
Sep 12, 2008 03:08 AM
jchrm80
Dec 20, 2007 12:41 PM
VTECth1s
Aug 3, 2006 01:01 PM
MelloYelloCRX
Jul 22, 2006 05:17 PM
CiViC SiR
Jul 4, 2003 02:24 PM
