Zeitronix boost sensor install help
Old May 29, 2005 | 07:22 PM
socalvibe's Avatar
Default Zeitronix boost sensor install help
Hey guys,
I seem to have lost the install instructions for my Zeitronix wideband kit. I had it all wired up and working good except my boost sensor wasn't in yet. Now that I have my boost sensor, I cant find my instructions. No PDF's on the website. I hooked up the green boost sensor wire to the orange wire on the zietronix harness and hooked up the black sensor wire to one of the brown wires on the zeitronix harness, the other brown wire goes to the ecu sensor ground. It reads "Boost 16" at idle thats not right in psi or in/hg, so I am not sure what im doing wrong. If any of you guys know how this should be wired I'd really appreciate it.
Thanks, Mark
PS I checked archived threads like this one: https://honda-tech.com/zero...age=2
But it seems like I have everything ok
Old May 30, 2005 | 03:05 AM
non-VTEC's Avatar
Default Re: Zeitronix boost sensor install help (socalvibe)
i got my zeitronix instructions right here in front of me.
yellow wire (+5V supply) -------- connect to red on boost sensor
brown wire (signal ground) ------ connect to black on boost sensor
orange wire (boost input)-------- connect to green on boost sensor
hope that helps
rockseeb
Jun 28, 2017 11:44 AM
barraea
Engine Management and Tuning
17
Jan 29, 2016 04:17 AM
juanchoenuncrx
Aug 24, 2007 04:48 AM
bipedbear
Jun 9, 2005 12:15 PM
