Zdyne base map for boost 72lb injectors
Old Apr 27, 2004 | 06:57 PM
B20fun's Avatar
Default Zdyne base map for boost, 72lb injectors
I am running the stock map sensor right now and just need something to get it running decent. Also if you have anything for the the 3 bar that would also be helpful.
thank you
Or someone that will help me tune it
Modified by B20fun at 11:17 PM 5/19/2004
Old Apr 28, 2004 | 12:53 AM
B20fun's Avatar
Default Re: Zdyne base map for boost, 72lb injectors (B20fun)
Is there even anyone that runs a zdyne these days
Old Apr 28, 2004 | 04:33 AM
shotty's Avatar
Call zdyne and ask them what to set base and gamma to for those injectors.
Old Apr 28, 2004 | 05:48 AM
MIKES's Avatar
Default Re: Zdyne base map for boost, 72lb injectors (shotty)
List your complete mods. I may have something for you but your info is vague.
Old Apr 28, 2004 | 10:05 AM
B20fun's Avatar
Default Re: Zdyne base map for boost, 72lb injectors (MIKES)
I have an 84.5mm 9:1 compression b20 ported ls head crower cams duration 249 / 251 JG intake manifold 62mm throttle body. Inovative turbo systems 60-1 t4.
Old Apr 28, 2004 | 11:48 AM
Rollo Lawson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20fun &raquo;</TD></TR><TR><TD CLASS="quote">Is there even anyone that runs a zdyne these days</TD></TR></TABLE>
you are only the second person on the earth that i've seen ask about the zdyne. the other person is Mikes.
Old Apr 28, 2004 | 03:02 PM
B20fun's Avatar
Default Re: Zdyne base map for boost, 72lb injectors (B16C1)
Well thats good to know.
Are there still people out there that can tune the Zdyne or am I going to have to do it myself.
Old May 4, 2004 | 09:43 PM
B20fun's Avatar
Looks like its time to buy a wide band and study up on timing
Old May 4, 2004 | 09:47 PM
Hoosier Daddy's Avatar
I'm on the same boat as you. We need more ZDyne tunes out there. Luckily, someone on here was nice enough to write me a basemap. What size injectors do you mean by 72lb?
ZDyne wont be able to tell you what to set for base/gamma. I called up about that and I was told to set it at 450cc and lean it out from there.
Old May 5, 2004 | 09:11 PM
leed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20fun &raquo;</TD></TR><TR><TD CLASS="quote">Well thats good to know.
Are there still people out there that can tune the Zdyne or am I going to have to do it myself.</TD></TR></TABLE>
I wouldnt worry about that. The GUI may look different, but they (Hdata, Uberdata, Crome, AEM) all edit the same basic maps.
Old May 6, 2004 | 08:25 AM
b20turboic's Avatar
Default Re: Zdyne base map for boost, 72lb injectors (leed)
i use zdyne still for my 90 si with a b20 making 300 whp and all stock motor. so yes it works great. tuning is easy
Old May 6, 2004 | 03:29 PM
B20fun's Avatar
Default Re: Zdyne base map for boost, 72lb injectors (b20turboic)
I got it running good just driving it around but I can't get it to boost. The 72lb injectors are about 700cc's. I think the problem might be the timing my timing light broke and I haven't had a chance to get a new one yet. I am only boosting 10lbs right now but I do want to try more.
Old May 19, 2004 | 10:16 PM
B20fun's Avatar
Any one have any recomendations for places to get it tuned in the nor cal area
Old May 19, 2004 | 10:31 PM
sporkcrx's Avatar
dynospot racing, located in San Jose.
http://www.dynospotracing.com Heard nothing but good about them
Old May 20, 2004 | 10:47 AM
Joseph Davis's Avatar
Speed Phreak runs a Zdyne. 2.0 LS, 8K revs, 750cc injectors. He knows how to make the power (120+ trap speeds, times all over the place), hunt him up.
lurkin' eg
Dec 16, 2007 09:11 PM
reactiondc2
Aug 15, 2006 06:59 AM
zbower7
Jul 13, 2004 07:23 AM
B20fun
Oct 30, 2003 10:54 PM
platinum00
Jun 9, 2003 05:18 PM
