z6 and y8 head??
the z6 in going to flow better though it'll have less compression.. typically the optimal stock head for turboing as it lowers your compression, and has pretty good air flow..
the y8 is going to have higher compression but flow a few CFM's less.. in my case where my compression is TOO low, i'll be using this and a mild port to make up the difference..
either way, i would DEFINATELY look into getting a zex 59300 cam for the z6, or a 105300 for the Y8..
