z6 Boost problems....
Old Mar 10, 2006 | 08:12 PM
BackupNyou's Avatar
Default z6 Boost problems....
Just threw in a boosted z6 and its running but my boost gauge shows 20 vacum psi and right when it revs up to 0 psi and bout to start boostin the motor bounces off rev limiter, like at 4 gran it cuts out, its running s200 and it runs fine befor it cuts out, what sources do you think could cuase this? i know it could be a lot of things but any extra knowledge could help
Old Mar 10, 2006 | 10:07 PM
Hybrid96EK's Avatar
Default Re: z6 Boost problems.... (BackupNyou)
One of two things come to mind
Launch control is enabled and the VSS isn't hooked up
Boost cut is enabled at a very low psi and its cutting out
Old Mar 11, 2006 | 07:21 PM
BackupNyou's Avatar
Default Re: z6 Boost problems.... (Hybrid93Eg)
its runnin low boost like 3 pounds i know it was set for over 10 in the last car this motor was in, it runs strong and as soon as it wants to boost, it cuts, it doesnt make sense, whats launch control and vss? how does that work
Old Mar 11, 2006 | 07:30 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BackupNyou &raquo;</TD></TR><TR><TD CLASS="quote">its runnin low boost like 3 pounds i know it was set for over 10 in the last car this motor was in, it runs strong and as soon as it wants to boost, it cuts, it doesnt make sense, whats launch control and vss? how does that work</TD></TR></TABLE>
A launch control problem would mean whenever you hit a specified RPM, it would cut out... you also would have no spedo at all, so thats most likely not it...
You SURE the ECU doesn't have boost cut perhaps? Could be a boost cut set very low causing it to cut out. Boost cut is a LOT like the rev limiter, only pretty damn harsh
Old Mar 14, 2006 | 07:56 AM
BackupNyou's Avatar
is there any way to check for boost cut or do i have to take it down to a shop that deals with hondata? Also how do i check what code im throwin?
Old Mar 14, 2006 | 07:57 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BackupNyou &raquo;</TD></TR><TR><TD CLASS="quote">is there any way to check for boost cut or do i have to take it down to a shop that deals with hondata? Also how do i check what code im throwin?</TD></TR></TABLE>
Dealer or someone with the Hondata software could tell you if boost cut is on the chip.
blackeg
Jun 20, 2011 12:14 PM
bigtom388
Nov 21, 2009 12:30 PM
rdeezy78
Aug 27, 2007 03:19 PM
BoostedH23a1
Aug 21, 2003 04:00 PM
