Z-Dyne Hard Startup Issues.
Old Sep 17, 2002 | 10:12 AM
SiR Kid's Avatar
New User
Default Z-Dyne Hard Startup Issues.
1st, the Setup: B16a w 550 Venom's, Holley Upgrade Pump, stock FPR, and a ZDyne Gold ECU.
What fuel startup % is everyone using on their Z-Dyne? I've run everything from 0 <VERY hard start> on 10% increments to 120% <fouled plugs> without anything starting in less than 5-10 seconds of cranking away.
Any help?
Old Sep 17, 2002 | 10:57 AM
RGAZ's Avatar
New User
Default Re: Z-Dyne Hard Startup Issues. (SiR Kid)
Have you looked at your main relay? maybe it isn't priming the system properly?
Randy
Old Sep 17, 2002 | 11:11 AM
SiR Kid's Avatar
New User
Default Re: Z-Dyne Hard Startup Issues. (RGAZ)
I can hear the fuel pump cut on, and stop a few seconds later.. Then I try to start it. I always let the pump cut off before trying to start it.
Old Sep 17, 2002 | 12:53 PM
reXem's Avatar
What about spark? if you are getting a weak spark won't that also make the car hard to start?
Old Sep 17, 2002 | 03:36 PM
SiR Kid's Avatar
New User
Default Re: Z-Dyne Hard Startup Issues. (reXem)
I've boosted 10-12 PSI without high RPM sputtering, I'd think that the Spark is strong enough
Old Sep 17, 2002 | 05:09 PM
shingles's Avatar
My crx developed a starting problem, then eventually wouldn't start.. turned out to be the ignitor....
93daintegra
Sep 30, 2008 04:58 PM
boostedpleasure
13
Oct 12, 2006 09:10 AM
SRCivic97
Oct 22, 2004 05:27 PM
hookedonvtec
May 27, 2004 08:17 PM
nitroacc0rd
Mar 1, 2003 11:08 AM
