Your Parts List
Old Jun 15, 2002 | 10:19 AM
int3gra's Avatar
Default Your Parts List
Post up a link to your parts list for Turbo Setup and/or Engine Rebuild.
You can email it to me at syndk8@rogers.com if its a Excel sheet.
I just want to know what else should I buy and what parts are missing.
Thanx
[Modified by int3gra, 2:20 PM 6/15/2002]
Old Jun 15, 2002 | 05:30 PM
DC2R714's Avatar
Default Re: Your Parts List (int3gra)
.50A/R T3/T4 Turbo
SFP Custom Manifold
Slim line Cooling fan
Custom DP 2.5"
Custom IC Piping 2.25"
Spearco Front Mount IC
Tial Wastgate
Vortech FMU
RC 310 CC Inj.
Turbonettics IC Connectors
Blitz DD BOV
New Ex. gaskets
Greddy Boost Gauge
Greddy EGT gauge
Instrument bezel
All Oil lines and return lines...
walbro 255lph fuel pump
NGK plugs
Magnacore wires
Missing link
Engine:
JE 9:1 forged pistons
Eagle rods
STR blockguard
greddy oil cooler
hope this is what your asking for. Haven't done the engine stuff yet.
Old Jun 15, 2002 | 08:32 PM
DigitalFusion's Avatar
Default Re: Your Parts List (DC2R714)
Hondata 2BD
AEM FPR
BBK FP
Inlinepro 3mm headgasket
ARP Head Studs
1G/2G DSM Injectors
10 ohm resistors
T3 - .60 comp/.48 turbine - 60 trim
Polish Comp Housing
Reman H2O center
Downpipe Flange
Nickel Plated Turbine
??? Manifolod ???
Tial WG
Custom IC from Ford SD
Coupling/clamps TB/pipe – IC/pipex2 – turbo/pipe 5 total
Bosch BOV
JC Whitney Sport Compact Piping (5 180’s)
Stainless Oil lines
[Modified by CustomCockpits, 5:16 PM 6/16/2002]
Old Jun 15, 2002 | 09:24 PM
M.A.R.C.'s Avatar
Default Re: Your Parts List (CustomCockpits)
Turbo Kit:
>Garrett T-25 Turbocharger
>Starion Intercooler
>TEC Wastegate Assembly (lower boost to 6psi)
>Custom Turbo Manifold??? <-- Any Suggestions ???
>Greddy Type-S OR HKS SQV OR Apex'i Twin Chamber Blow Off Valve
>JC Whitney OR Custom Charge Pipes
>Custom Downpipe (Miami Muffler)
Fuel System:
>DSM 450cc Injectors
>88-91 Injector Resistor Box
>255lph Walbro High Pressure Intank Fuel Pump
>RC Injector wire clips
Electronics & Gauges:
>Apex'i V-AFC
>PocketLogger for OBDII (thinking bout it... got a palm pilot for free)
>Greddy Turbo Timer
>Autometer Sport-Comp A/F Ratio Gauge
>Autometer Sport-Comp Boost Gauge
>Autometer Dual Gauge Pod
>NGK BCPR7ES-11 Spark Plugs
Miscellaneous:
>Oil-line Kit
>Gaskets, Vaccum hoses, silcone hoses, coolant lines, etc
Any suggestions/recommendations anyone?
OK all I got left to buy is the wastegate assembly, manifold, BOV, charge pipes, downpipe, RC Injector wire clips, spark plugs, Oil-line Kit, Misc stuff (gaskets, vaccum hoses, silcone hoses, coolant lines, etc)
[Modified by CivicRyda2k, 1:30 AM 6/16/2002]
Old Jun 15, 2002 | 09:58 PM
kidkutz's Avatar
Default Re: Your Parts List (CivicRyda2k)
Turbo:
GT3040 Twin Ball-bearing turbo
Tial 46mm Wastegate
Tial 50mm BOV
Custom Manifold
Spearco Liquid-to-air Intercooler
Engine Block:
Iron Sleeved Block
Endyn/Wiseco Rollerwave Pistons
Pauter Chromoly Steel Rods
Knife-edged and balanced crank
Balance Shafts removed
Aluminum Crank Pulley
Pro Drive Oil Pump Gear
Engine Head:
Ferrea Super Alloy Valves
Crower Dual Valve Springs & Titanium Retainers
Port & Polish
Venom Intake Manifold
Cometics Head Gasket
Fuel:
Bosch 960cc Injectors
Bosch Fuel Pump
Paxton FPR
STR Fuel Rail
Stainless Steel Lines
Russell Fuel Filter
Ignition:
MSD 7AL-2
MSD Pro Power HVC Coil
MSD Launch Control
MSD 8.5mm Wires
Transmission:
Quaife ATB Differential
ACT Xtreme Pressure Plate and 6 Puck Disc
13.5lbs lightened flywheel
Management:
AEM EMS
HKS EVC III
Misc:
Flex-a-lite Dual 12" Fan
Flex-a-lite Oil Cooler
Jabsco Centripuppy Water Pump
RCI Aluminum Cell
StrangerWitCandy
Mar 24, 2004 01:29 PM
project
Jan 3, 2004 02:45 AM
97itr86
Jan 3, 2003 10:56 AM
DC2R714
Jul 11, 2002 04:46 PM
