Clutch Disk
Old Dec 8, 2006 | 02:09 AM
vti2's Avatar
Default Clutch Disk
Witch is the strongest sprung clutch disk that i can buy?
It schould hold 500whp on a street car. dailydriver
Old Dec 8, 2006 | 04:32 AM
oscarmayer's Avatar
you don;t buy jsut 1 part of a clutch. you have to buy a matched set for it.
so you have to get the pressure plate and disc as a set that are designed to work together.
a bunch of clutch will support 500 but the issue is what are you going to do witht he car? street w/o slicks or track duty too with slicks? the kind of driving your going to do is going to decide what clutch will work for you.
in today's day and age, you might as well just go out and buy a twin disk setup. it's liek $1200 but will keep you form having any issue and can take street and track duty. they are just very sensetative.
Old Dec 8, 2006 | 04:45 AM
redzcstandardhatch's Avatar
something different
Default Re: (oscarmayer)
you can mix and match many brands of discs/PPs.. they are usually a stock-sized replacement, made of different materials. not everything will work with everything, so you might want to make sure they work together if your going mix/match
i have ran different brand stuff together, but i would recomend buying a matched set.
action clutch seems to make some good stuff, as do ACT, clutchmasters
or, go all out, with a twin disc.
Old Dec 8, 2006 | 04:47 AM
SPOOLINmatt's Avatar
Default Re: (redzcstandardhatch)
i made 630 on a stage 5 competition clutch, it slipped on the dyno some, but on the track it never slipped. Then i switched to twin disc.
Old Dec 8, 2006 | 10:30 AM
s2kdre's Avatar
Default Re: (SPOOLINmatt)
tilton is the shiat
Old Dec 9, 2006 | 11:55 AM
vti2's Avatar
I have a Exedy stage 2 PP Is in very good condicion but the clutch disk is gone. Normaly i only ne a new disk.
dc4teg
Jul 30, 2011 11:24 AM
turboedsupe
Apr 18, 2008 01:46 PM
JDM97R
Feb 7, 2008 09:17 AM
jman86
Jan 17, 2006 08:31 PM
Honda Bull
Dec 25, 2004 04:23 PM
