y8 blowing smoke?
hey guys i have a d16y8 in my hatch and running a t3/t4 50 trim turbo. I am getting white or gray smoke and alot of it, I thought was the turbo so i put a new on in and same problem. The car is on a crap of a tune just waiting to get to the shop. The car is running very lean if you boost on it the wide band reads up to about 16 when think it should be at about 12-12.8. I dont get on the car not trying to blow it up, My question is could the tune being so bad cause it to smoke bad or am i looking at rings or valve guides some one plz help me thanks alot
White smoke is usually coolent.... Headgasket maybe. and since you know it leans out to 16 that means u obviously spooled the turbo up, could be a lot of things after that! Do a compression check and report back
thanks guys i dont think it is the head gasket i have not done compression test yet going to do tomorrow but when i pull the oil cap i get some smoke coming out of it and there is oil residue on the muffler tips inside. I have been looking around on line could this be caused by pcv valve i know its a long shot but whats your thought
If the problem was your PCV, I HIGHLY doubt you would ever be drawing in enough oil to coat your exhaust.
How much boost are you running? It is possible your head is lifting when you do hit boost causeing "blow by" that would cause white smoke and oil to burn off also, but if your compression is good id definalty suspect the headgasket
eg9d16turbo
32
Dec 14, 2010 07:33 AM
huntsturbocivic
Apr 22, 2007 05:17 PM
civicturbo22
Jun 8, 2005 09:54 AM
