xtd clutch
Old Jan 1, 2008 | 02:25 AM
  #26
blinx9900's Avatar
Default Re: (aladdin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Glove &raquo;</TD></TR><TR><TD CLASS="quote">i got the stage 3 6 puck with the flywheel,
the flywheel did not fit properly and the bearing was the wrong one, but the clutch worked fine, they took back the flywheel for a refund after some arguing. So i got a competition flywheel instead, and using the xtd stage 3 on my turbo teg, its still holding up good after 6 months, but havent used it at the track yet.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deucedeuceEK &raquo;</TD></TR><TR><TD CLASS="quote">xtd 6puck and flywheel on h22 with 7lbs of boost. Holds up fine and has never slipped. Only thing I dont like is that the clutch petal is not stiff and feels pretty stock. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aladdin &raquo;</TD></TR><TR><TD CLASS="quote">I have the XTD 6 puck. Absloutly not your daily driver clutch It used to chatter like crazy during the break in period. It still chatters but not like the first 500 miles. I have put 5000 miles on it so far with no problems other than the chatter.
I will def save up for a good brand next time.
and you guys are all making how much tq? cause im making 260wtq and the clutch is NOT holding, they advertise 278tq so i guess its not like there lieing too much... but still, i would NOT buy again.
Old Jan 1, 2008 | 09:22 AM
  #27
97grnrs's Avatar
Default Re: (blinx9900)
only thing i would use from Xtd is the actual disc itself.. everything else ive had problems with but the 6 puck disc never broke on me.
Old Jan 4, 2008 | 01:20 AM
  #28
salman's Avatar
Default Re: (97grnrs)
Well so far The Inputs are not that bad, 70:30.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">only thing i would use from Xtd is the actual disc itself.. everything else ive had problems with but the 6 puck disc never broke on me. </TD></TR></TABLE>
Thats wht ill be doing too, Ill be using only CLutch disc... Ill install it on 8th.
ill keep u Guys posted..
Old Jan 4, 2008 | 02:00 AM
  #29
blinx9900's Avatar
Default Re: (salman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salman &raquo;</TD></TR><TR><TD CLASS="quote">Well so far The Inputs are not that bad, 70:30.
i just hope your not boosted....
Old Jan 4, 2008 | 06:58 PM
  #30
97grnrs's Avatar
i was boosted with 16 psi on a 57 trim turbo and it held..
Old Jan 4, 2008 | 07:04 PM
  #31
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i was boosted with 16 psi on a 57 trim turbo and it held.. </TD></TR></TABLE>
how much power/tq were you making? what type of tires did you have? and which stage clutch?
Old Jan 4, 2008 | 09:12 PM
  #32
quicksilver1689's Avatar
i ♥ snails
yeah i have used those xtd stage 3 clutches before they work ok for moderate builds, im surprised how "off balance" it was. i wouldnt use them for anything over 320-340whp
Old Jan 4, 2008 | 10:04 PM
  #33
blackccoupe's Avatar
Default Re: (quicksilver1689)
my buddy using one, ls turbo t3t4 ,holds just fine no problems has over 1500 mile son it ,beats on it all the time
Old Jan 4, 2008 | 10:11 PM
  #34
civic_sc's Avatar
got a stage 3 last year w procharger 14 psi 320whp 210lbs and made a year of drag racing and driving launching at 7800 on 24.5 mickey it alway grip as well....stage 3 w flywheel...
now i have a stage 5 from xtd and will see next summer how it does with more whp..
i did but like 25 kit since and no custumer never brake anything ...most of them drag racer ...
the only problem one was w a cable transmition and a hydro clutch kit ythe pressure plate made the same as the pics in the first page...
for the price it s really good go for the stage 5 if you are putting down a lot of power....it s a special order but they can do it ,,
here a video http://smg.photobucket.com/alb...1.flv
hope this will close this thread ...
good luck buddy
Old Jan 4, 2008 | 11:40 PM
  #35
blinx9900's Avatar
i guess its the fact that im making a lot more tq than the rest of you guys, that might explain why mine is starting to slip, 260wtq. its not that high. but if you realize its 306 tq at the flywheel i guess thats a lot for the clutch...
Old Jan 6, 2008 | 07:33 AM
  #36
civic_sc's Avatar
you wont break a stage 4 ....or 5 ...if you are running a stage 3 i think your tq is too much for a stage 3....
Old Jan 6, 2008 | 10:05 AM
  #37
ej8's Avatar
ej8
Default Re: (civic_sc)
The XTD "stage 3" has a generic stock spec pressure plate. The stage 4+ have the higher clamploads, but I still don't know if I would trust it. My pressure plate was lifting on my setup and the clutch wouldn't hold (new flywheel, new xtd s3 clutch kit) at the dragstrip, just slipped when on 24.5 tall BFG drag radials. I called them up and they wouldn't do anything about it other than try to sell me a stage 4 clutch which is what they say you have to have with turbo....screw that...
Now I'm using an ACT 6puck unsprung w/ ACT HD PP now with NO issues EVER, holds perfect and I drive it every single day Another great clutch is competition clutch
Old Jan 6, 2008 | 11:19 AM
  #38
blinx9900's Avatar
Default Re: (ej8)
i think im gonna get the new blade carbon clutch from carbonetic if the price is right... looks promising...
Old Jan 6, 2008 | 02:23 PM
  #39
ScorpioMk's Avatar
friend made 320-365hp and 300-330trq in his drift car (1jz cressida) and his xtd lasted just over a year daily driving, always drifting, many track events, clutch kicking etc. My friends boosted KA-T 240 didnt hold his trq from the start (250ish maybe). We have been using them a lot in corollas or seeing them used a lot and they work great NA. But for FI cars i would really just buck up and buy an act or something along the lines. Spend 400 now, or spend 150 then spend another 400 when the xtd doesnt do what you thought it would.
Marcus
Old Jan 6, 2008 | 11:41 PM
  #40
ekhonda87's Avatar
Default Re: (ScorpioMk)
i would just fork out the money for a good clutch, cause there is nothing worse than a slipping clutch....
Old Jan 7, 2008 | 12:28 AM
  #41
gq420j's Avatar
just installed a stage 3 with the flywheel and i am not having no problems at all. still in the process of breaking it in.
Old Jan 7, 2008 | 04:33 PM
  #42
blinx9900's Avatar
Default Re: (gq420j)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gq420j &raquo;</TD></TR><TR><TD CLASS="quote">just installed a stage 3 with the flywheel and i am not having no problems at all. still in the process of breaking it in. </TD></TR></TABLE>
well of course your not having problems, you just installed it
Old Jan 7, 2008 | 05:11 PM
  #43
user 98292739's Avatar
im using one but i cant comment quite yet im still running N/A on my stage 3 for 3k miles...it doestn slip but im not turboed yet.
but i do know myf riend has the mustang xtd stage 3....he is makign over 600 lbs of tq and it holdsi t all. no slip
Old Jan 14, 2008 | 11:48 AM
  #44
salman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
i just hope your not boosted....</TD></TR></TABLE>
Yes i am not boosted, I am Running Bone stock B16
Old Jan 14, 2008 | 03:05 PM
  #45
Crx Jimmy's Avatar
It has been fine for me for 2 years, Im using their heaviest pressure plate with a stock exedy organic disc(need the smooth transition for auto-x tried the 6 puck too grabby) . On a JRSC b16 8psi.
Old Jan 14, 2008 | 03:31 PM
  #46
MindLess311's Avatar
I ran one as a back up on my car last year. I was making 300whp not sure about tq but im guessing around 200 and it would slip on me sometimes. Oddly enough it would hold fine at the track but not on the streets for highway pulls.
Old Jan 14, 2008 | 09:39 PM
  #47
paulzy's Avatar
with all these hit or miss issues, why not fork out the extra $100 or so and get a good clutch from a reputable company and be done with it. I don't know about you guys but I don't find reasons to crawl under my car and buying this clutch sounds like a very good chance to spend even more money for a good clutch and R&R the assembly again which isn't fun at all.
Old Jan 14, 2008 | 11:09 PM
  #48
I run a Comp Clutch got it from xenocron for a good price made it threw a full season with 0 problems and i will be running it again next season. And thats coming from me who with alot less power went threw about 4 or 5 clutches 2 seasons ago
kingcu90
25
Jun 18, 2009 09:35 PM
Rickcrx
Apr 20, 2006 04:16 PM
PsychoSiRex
10
Jul 28, 2004 08:39 PM
jdmitch
May 29, 2004 10:15 AM
