XTD clutch
Old Jan 12, 2007 | 03:19 AM
  #26
SpeedwaySlick's Avatar
Default Re: (SpeedwaySlick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedwaySlick &raquo;</TD></TR><TR><TD CLASS="quote">
But my car is a daily driver, so I'm wondering how is city driving with the XTD stage 3?</TD></TR></TABLE>
Old Jan 12, 2007 | 03:37 AM
  #27
wicked2night's Avatar
Default Re: (mr_hahn73)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_hahn73 &raquo;</TD></TR><TR><TD CLASS="quote">Get the stage 3 kit! It is very easy to drive and grips very hard! </TD></TR></TABLE>
Maybe send a PM to this guy, he should know how it is. But from what i heard it's not too stiff for a DD.
Old Jan 12, 2007 | 03:51 AM
  #28
akira712's Avatar
Default Re: (wicked2night)
driveabililty is excellent im runnig a stage 3 and like it...mine started to slip on the dyno after 330whp, but thats over its rating anyway
Old Jan 12, 2007 | 04:19 AM
  #29
Default Re: (eastcoast_ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastcoast_ej &raquo;</TD></TR><TR><TD CLASS="quote">driveabililty is excellent im runnig a stage 3 and like it...mine started to slip on the dyno after 330whp, but thats over its rating anyway</TD></TR></TABLE>
That was a helpful comment. I ordered the stage 2 based on the claim in the item description that it would take up to 260 tq. If the stage 3 started slipping after 330 whp (and 260 tq, according to your sig), it sounds like the stage 2 wouldn't give my setup much room to grow.
Old Jan 12, 2007 | 06:05 AM
  #30
Hybrid96EK's Avatar
That was a helpful comment. I ordered the stage 2 based on the claim in the item description that it would take up to 260 tq. If the stage 3 started slipping after 330 whp (and 260 tq, according to your sig), it sounds like the stage 2 wouldn't give my setup much room to grow.</TD></TR></TABLE>
Seriously you should be happy and thankfull that they sent you the 6 puck. The full face is kind of a joke in a way. Its something I would put in a car with basic bolt ons or stock. I would NOT trust it behind a turbo. The 6 puck is more suitable for a boosted setup and even then they don't reccomend it for boost. They have a stage 4 they actually say is the one you should use for boost.
As for driveability, I use the 6 puck XTD and I say its awesome. Its NOTHING like the 6 puck's you get from ACT. Trust me. I've driven those and they are like an on/off switch. Its not pleasant. The XTD is very forgiving and easy to drive on the street. The material on the disc won't destroy your PP or flywheel either like the ACT's do.
Old Jan 12, 2007 | 06:30 AM
  #31
CroteTurbo's Avatar
Default Re: (Hybrid93Eg)
I ran a stage 4 PP with stage 3 disk(6 puck sprung) cause It's my daily driver.
May be I shouldn't have done that, anyway, here how it was running.
Once break-up, it hold boost pretty well even at 15psi ~350whp with slick at the drag. It never slip at all.
Brake pedal was heavy but I was ready for that in a stage 4
But engagement was really strange, sometimes the clutch was high and begin to grip slowly, sometimes the clutch was low and start to grip hard at once.
I pull the clutch out at 15k km and the disk was still perfect even after sliping it on start at the drag, the PP was ok too.
My advice, go with the stage 3 I only heard good thing about it, if you need more then go with known brand.
Old Jan 12, 2007 | 08:04 AM
  #32
akira712's Avatar
No problem
before i bought it i did some research and found that the disks sucked but the pucks were decent... for what you pay
i would tell anyone (up to ~300whp) to get the stage 3 if there thinking about going with the xtd.
Old Jan 12, 2007 | 07:33 PM
  #33
blinx9900's Avatar
Default Re: (CroteTurbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CroteTurbo &raquo;</TD></TR><TR><TD CLASS="quote">
mine does that too (stage 3), have you checked your mc or slave-c? im going to check mine.
Old Jan 17, 2007 | 05:45 PM
  #34
dblock2x's Avatar
does anyone use a stage 4. i am lookin to get a 6 puck unsprung and im only about to make 215whp all motor. any suggestions?
Old Jan 18, 2010 | 08:26 AM
  #35
crix868's Avatar
Default Re: XTD clutch
i used the stage 4 - 4 puck sprung on my Turbo LS on 9psi DD, anyone who drove my car including my mom swore up and down it was a stock clutch. as a side note i also had a Findanza 7.5lb flywheel with this setup. worked great i loved it alot. i'm really thinking about getting one for my TSX now.
Old Jan 18, 2010 | 08:33 AM
  #36
jksmith's Avatar
ran stg3 on my NA LS/V only got 1000 miles before the motor blew, but clutch was awesome!!
Old Jan 18, 2010 | 08:57 AM
  #37
welfarepc's Avatar
Originally Posted by SpeedwaySlick
Looking for some reviews of XTD clutches and flywheels, from people who have actually had them installed on their car. I've yet to hear someone (who has actually used them) say something bad about them.
they work great for low torque applications.
i had an xtd "stage 3" installed on a fresh flywheel, slipped at 140wtq.
went comp clutch and never looked back. oh and the comp clutch was just over $300, not bad at all.
Old Jan 18, 2010 | 09:12 AM
  #38
b16racereg6's Avatar
my friend has a xtd stage 2 in his n/a integra b20 he has put 20k + on it and its still the same it has been the same from when we put it in. he still drives on it today. but if i was going boost anything 300hp like 250+tq id go name brand.. or buy the next stage above what xtd recomends. g/l man. o yeah dd should be fine u will get use to it in a matter of time.
Old Jan 18, 2010 | 11:49 AM
  #39
Glove's Avatar
I had a stage 3,
it started to slip RIGHT around 270 wtq,
which is pretty bang on in terms of the ebay description.
but they dont take heat well, spinning slicks on the track then running is a no-go, it just slips with any kind of heat.
for a street car, stock motor, they work real good.
Old Jan 18, 2010 | 03:02 PM
  #40
Pay2play killa's Avatar
ran an xtd ceramic metallic on my turbo D @ 220whp for about 6mo; no problems, slight jerkiness but thats the nature w/ ceramic metallic clutches. when the motor died the clutch had hardly any wear on it
running the same clutch (but for B series obviosly) on my built ls/vtec setup now; clutch is a bit jerkier than my D but holds good and even w/ a cable clutch its not too heavy
Old Jan 18, 2010 | 03:47 PM
  #41
Turbo-LS's Avatar
The XTD kinda suck. if you really want to save money and want a pretty decent clutch pick up an F1 stage 4 sprung disc. i have this on my car now for over 20k miles and it still bags gears. It will no longer hold 3rd gear burnouts but it doesnt slip at all in driveing conditions and i drive hard
Old Jan 18, 2010 | 04:37 PM
  #42
2ndchirp's Avatar
I had the xtd stage 4 unsprung... one trip to the track after 2months the xtd pressure plate cracked causing damage to clutch and flywheel... now i have the stage 3 with 9lb fidanza flywheel and no problems yet but its only been a month
Old Jan 19, 2010 | 04:17 AM
  #43
Turbo-LS's Avatar
i didnt say the xtd stage 4, i said the F1 stage 4, there different clutches. benn running mine for long time. its been to the track with 24.5 slicks and 3rd gear burnouts in the past. still kickin just wont hold the burnouts anymore
Old Jan 19, 2010 | 04:51 AM
  #44
GsrIntegra789's Avatar
Why dont you just run a stock clutch?
Old Jan 19, 2010 | 07:46 PM
  #45
acuraturbo90's Avatar
well i have mine for 4yrs and not problem at all thanks to jim at xtd clutch i allways call him first before il buy it so he can guide me wich one i need im running ls/vtec 19 psi 443hp/343tq and still kicking
sorry im running stage 3 with 2,500 ps plate
Old Jan 19, 2010 | 09:16 PM
  #46
_kiid's Avatar
damnn what stage are you running?
what stage is good for 350whp+?
Old Jan 19, 2010 | 09:28 PM
  #47
_kiid's Avatar
i think ima order a stage 4
all b series trannys are the same clutches right?
Old Jan 20, 2010 | 12:59 AM
  #48
K7-1Ktrevor's Avatar
Loved
Community Favorite
my xtd stg 2 slipped with 23" slicks on my all motor car. overall felt like stock but held to 230whp/155tq.
Iv had a stg 3 on a turbo b16 and never a problem. good clutch for the money.
Old Jan 20, 2010 | 01:00 AM
  #49
Loved
Community Favorite
hydro and cable clutchs are different.
Old Jan 20, 2010 | 03:59 AM
  #50
Turbo-LS's Avatar
they say hudry and cable clutches are different but ive run both in both style trannys without a problem. if its a 90-91 cable then its different but if its 92-93 cable then it shouldnt matter. BUT its always best to order it for the correct year just to be sure
