wrong distributor??? (check out pic)
hey guys yet another problem...i took off the cap and there was a scew just layin inside there first of all..and the part number reads TC-08A which is for an od2 gsr or type r. Now the motor is 96b18b1 boosted in a 92 civic..is this the wrong distributor?........and i am going to get a new one but which one should i get?
That is the rotor screw. Locktite blue will hold it in fine if you have problems.
The distributor is fine. All the OBD2 or OBD1 b-series internals will work. No need to get another one.
thanks will try it...you think that what its cause it to break up about 3000-4000 rpms?
this cant be the rotor screw. the ends not broke, and theres no hole in the middle of the rotor to scew it unless it goes somewhere elese not sure never messed it it before
nevermind found the hole on the side will try it out soon and let you guys know..thanks for all the help fellas!!....but is that distributor ok to use?
you can rotate the distrubutor a little bit clockwise (retard) or counterclockwise (advance)...you should loosen the 3 dist. bolts and get a timing light and set it to stock ignition timing....just to make sure its ok when u take it in for tuning.
man what is stock i havent done it in ahwile 14? 16?
Distributor will work. 16 degrees. Good luck. Might want to get a manual while you are at it. Sounds like some basic things are still ahead of you.
www.helminc.com
www.helminc.com
yeah been out of the game for yearssss
www.helminc.com
www.helminc.com
