would an exedy stage 1 organic clutch be able to handle s/c gsr ?
I have an exedy stage 1 organic + fidanza flywheel 7lb. that I originally purchased for my NA setup. Plans have changed and im going with jrsc would my clutch setup be able to handle the increased torque?
Re: would an exedy stage 1 organic clutch be able to handle s/c gsr ? (SneezR)
it should for a while. I run 10 psi with turbo with a stage 1 competition clutch thats 45% stronger than stock. And it still grabs just like from day 1.
Re: would an exedy stage 1 organic clutch be able to handle s/c gsr ? (jdmhonda)
i don't think you should be worried as much as i am... i'm going to be running stock clutch until it goes out with my 7lb turbo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">it should for a while. I run 10 psi with turbo with a stage 1 competition clutch thats 45% stronger than stock. And it still grabs just like from day 1.</TD></TR></TABLE>
Me too. Mine has about 45K on it too. I'm using an exedy organic btw.
Re: would an exedy stage 1 organic clutch be able to handle s/c gsr ? (RacerXI)
I plan going with the exedy organic for my d17 on 10psi. But I have my stock 90k miles clutch now and its hold pretty good for now.
Re: would an exedy stage 1 organic clutch be able to handle s/c gsr ? (Hyaboosta)
My exedy was holding fine at 10 psi on my greddy turbo. When I went to 13psi it started to slip a little. I know a few people running 12psi and 10 psi with Jacksons that hold strong.
