would colder spark plugs lower engine temp?
Old Apr 16, 2007 | 08:25 PM
the.hamburglar's Avatar
Default would colder spark plugs lower engine temp?
kinda a stupid question but i have stock ones in right now and its getting a tad hot. ill be getting some new plugs sometime but maybe i should get them right away. sorry if this sounds stupid.
Old Apr 16, 2007 | 08:32 PM
tony413's Avatar
yes but how much you boosting ? if its over 10psi then try 1 or 2 ranges colder than stock
Old Apr 16, 2007 | 08:38 PM
Default Re: (tony413)
.5bar. ~7-8 psi. its just geting about 5/8 of the way up over the middle temp and my fans are maxed out. i just bought a slim fan. i know this will help but im thinking i might be able to run a degree or two more of timing without pre det. thanks
Old Apr 16, 2007 | 08:41 PM
tony413's Avatar
then at one range colder you should be good basic FI rule
0-5 psi- stock
5-10psi- one range over
10-15psi- two ranges over
15-up- three ranges over
tuoniz
Aug 16, 2005 11:30 AM
92HB_HB
Jul 20, 2004 04:46 PM
itr817
Jul 26, 2003 06:10 PM
skierGT
Jun 17, 2003 05:06 AM
Qwikrex
11
Jan 20, 2003 11:52 PM
