IT WAS WORTH IT.....
Old May 21, 2006 | 12:14 PM
rhdune16's Avatar
Default IT WAS WORTH IT.....
Well thanks to a bunch of friends helping me I got the turbo installed started the bitch up and MAN it sound FAWKING SIICCCCKKKK!!!! I'm at 5 pounds and it feels faster than last year when I was at 11psi (3" open downpipe makes a huge difference, I love it) My question is will a side exhaust make a difference from an open downpipe because I already got high from the fumes???... anyways... here is the setup and the pics....
Wiseco 85mm Forged Pistons
Crower Billet Rods
CP Piston Rings
ACL bearings
ARP Head Studs
XTD Stage 3 Clutch
XTD 11lb Chromoly Flywheel
Rebuilt Stock Head
(A/C removed, P/S removed, All EGR and Emissions stuff removed)
Borg Warner GM8 Turbo
SPF Manifold
3" Downpipe
3" Straight Piping Side exhaust
2.5" Intercooler Piping
31x9x3 Intercooler
Tial 50mm BOV
Tial 38mm Wastegate
3Bar Map Sensor
550cc RC Injectors (I might need 750cc for the power range)
AEM Fuel Rail
Aeromotive Fuel Pressure Regulator
Stainless Fuel Lines
Greddy Catch Can
P06 Chipped for Uberdata
Boost, Oil Pressure, and EGT Gauges
I plan on turning up the boost when I get money because I am running on a basemap now that goes up to 11psi. It feels really really good though. I like it alot. It runs strong and hard. I already beat an M3 on the highway and was shocked. This is what I was waiting for and now I am done. You can check out the build here.... https://honda-tech.com/zerothread?id=1554011
Modified by rhdune16 at 2:22 PM 5/25/2006
Old May 21, 2006 | 12:15 PM
SuperSi's Avatar
Default Re: IT WAS WORTH IT..... (rhdune16)
tune it and you will feel even better.
Old May 21, 2006 | 12:21 PM
nonvtecD's Avatar
don't run 11psi on a basemap. what motor is that? looks good.
Old May 21, 2006 | 01:21 PM
s2kdre's Avatar
Default Re: (nonvtecD)
f22
Old May 21, 2006 | 01:27 PM
NVturbo's Avatar
O.G. triple O.G.
side exhausts are nice....just make sure it's not ghetto looking.
Old May 21, 2006 | 01:49 PM
99blusi's Avatar
Default Re: IT WAS WORTH IT..... (NVturbo)
Looks pretty good. I didn't realize you were from michigan until I saw the Milan pictures.
Look out for a EBP Si out there this summer. I'm finishing the tuning now.
As for the side exit, I've got massive clearance problems, I couldn't imagine losing 3 of the 4 inches that I have...
Don't know if you have been or are a member, but here's a good local forum for you to check out.
http://www.xceedspeed.com
Modified by 99blusi at 1:47 AM 5/22/2006
Old May 21, 2006 | 04:29 PM
2LiterTurboSeR's Avatar
Default Re: IT WAS WORTH IT..... (99blusi)
A little off topic but is that a gold compressor housing? That looks pretty neat... Got any more pics?
Old May 21, 2006 | 06:15 PM
bebfsu1's Avatar
Default Re: IT WAS WORTH IT..... (2LiterTurboSeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LiterTurboSeR &raquo;</TD></TR><TR><TD CLASS="quote">A little off topic but is that a gold compressor housing? That looks pretty neat... Got any more pics?</TD></TR></TABLE>
I wanna see more pics too!
Old May 21, 2006 | 06:52 PM
AbitAvenger's Avatar
Default Re: IT WAS WORTH IT..... (bebfsu1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bebfsu1 &raquo;</TD></TR><TR><TD CLASS="quote">I wanna see more pics too!</TD></TR></TABLE>
Old May 21, 2006 | 07:28 PM
JDM_EM1's Avatar
Default Re: IT WAS WORTH IT..... (AbitAvenger)
Old May 21, 2006 | 07:41 PM
SOHC_MShue's Avatar
Default Re: IT WAS WORTH IT..... (JDM_EM1)
setup looks CLEAN
Old May 21, 2006 | 08:19 PM
igo4bmx's Avatar
make sure u get a dumptube made!
Old May 21, 2006 | 08:52 PM
rhdune16's Avatar
I have the dumptube and stuff but just needs to be cut and turned the other way....
here are more pics of the compressor housing....
Old May 21, 2006 | 10:14 PM
racinskittle's Avatar
Damn, I like the way that manifold positions the turbo.....where'd u get that?
Old May 22, 2006 | 12:45 AM
bigdaddyvtec's Avatar
* B A N N E D *
Default Re: IT WAS WORTH IT..... (racinskittle)
Glad you got er done again man!!! Welcome back to the Dark side!!!!
ANOTHER BOOSTED F22 ACCORD!!!!
SOHC
FTW!!!
Old May 22, 2006 | 12:50 AM
TIGboy's Avatar
Default Re: IT WAS WORTH IT..... (bigdaddyvtec)
call me today and we can tig the rest of your downpipe.
Old May 22, 2006 | 01:42 AM
SoEvoL's Avatar
Default Re: IT WAS WORTH IT..... (SMSFAB)
nice
Old May 24, 2006 | 09:32 PM
rhdune16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle &raquo;</TD></TR><TR><TD CLASS="quote">Damn, I like the way that manifold positions the turbo.....where'd u get that?</TD></TR></TABLE>
The manifold is a sfp manifold... from what I heard they went out of business... I,personally, don't like the manifold at all. I don't like how it's angled because it clutters up everything and adds unnecessary bends to the downpipe... anyways next summer should change almost more than half of the motor/turbo setup....
Old May 24, 2006 | 09:56 PM
TurboJesse
Guest
Posts: n/a
I maybe wrong but isnt' that their ac manifold where the compressor is meant to be on the passenger side?? it would make more sense.
Old May 24, 2006 | 10:00 PM
rhdune16's Avatar
yes it is but I can't fit a 3" downpipe on that side to where i would clear the crossmember and the block (DAMN ACCORDS)
Old May 24, 2006 | 10:23 PM
b18sihatch's Avatar
man that looks sweet i cant wait till im where you are
Old May 24, 2006 | 11:03 PM
H.A.R.T B18C1EG6's Avatar
Default Re: IT WAS WORTH IT..... (b18sihatch)
nice
Old May 25, 2006 | 12:44 AM
Mugen112's Avatar
um.. is that a vacume line going from you plenum tank on you intake manifold to your crank case? If so, I would remove that immidiatly (sp?).
other than that, that setup looks nice! Where did you get your basemap from?
Old May 25, 2006 | 12:57 AM
SiR99's Avatar
damn, your car has so much room in the engine bay lol. Looks good tho
Old May 25, 2006 | 01:17 AM
* B A N N E D *
Default Re: IT WAS WORTH IT..... (SiR99)
Ya man I looked into an SFP too... I didnt much care for it either (not that I think its a piece of ****).
I got a Stainless"mini tubular" from mike at LSD Motorsports A/C and PS compatable, great WG placement and love it...Have a 3" DP that is no where near anything... Kept the front motormount too.... Mike took GREAT care of me. Mani works great, no cracks nmo trouble. When I got it, i cleaned up the inside of it, had it ceramic coated, and ROCK IT!!!
Just fyi if your looking around... I know you had the ramhorn last time around... I thought about it, but wanted to keep allmy ****. If interested, I can send some pics... Nice Build man!!!!
