working out CR
Old Apr 16, 2008 | 05:55 AM
Dave_yd's Avatar
Default working out CR
hi,
ive recently acquired this block, the owner didnt know the CR of the pistons so im wondering if there is a way i can work it out, they are JE's
dave
Old Apr 16, 2008 | 06:40 AM
96 GSR-T's Avatar
Why is the deck filled on opposite sides around each bore?
Old Apr 16, 2008 | 09:48 AM
Dave_yd's Avatar
its a common method of installing aftermarket sleeves here in the UK
Old Apr 17, 2008 | 03:27 PM
inspyral's Avatar
Default Re: (96 GSR-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T &raquo;</TD></TR><TR><TD CLASS="quote">Why is the deck filled on opposite sides around each bore?</TD></TR></TABLE>
Looks to be a welded-in block guard.
Old Apr 17, 2008 | 05:08 PM
AdamB18C1EK's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">
Looks to be a welded-in block guard.</TD></TR></TABLE>
yup. it is.
Old Apr 17, 2008 | 06:19 PM
96 GSR-T's Avatar
Well I can tell that much, I just figured there was a better way to weld the blockguard than filling that whole area with weld and them decking the block
OP: if you google "honda displacement calculator", you will find what you need. You will have to know what kind of head you will be using, rod length and crank type, how much your head/deck has been milled, the dome displacement/height of the pistons etc to get an accurate CR number
Old Apr 18, 2008 | 01:42 PM
Dave_yd's Avatar
^ yese i agree its not the tidiest job and i think i will have it down to a machine shop to "trim" the weld down.
I would like to know the CR of the pistons in there, the guy didnt who i bought it off didnt know so is there any way of working out what CR the pistons are, i presume they are 9.0:1 or therabouts.
Dave
Old Apr 18, 2008 | 07:09 PM
DRIVENRacing's Avatar
9-1 or or 8-8-1 either or lower compression..
Old Apr 18, 2008 | 09:18 PM
blinx9900's Avatar
Default Re: (DRIVENRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRIVENRacing &raquo;</TD></TR><TR><TD CLASS="quote">9-1 or 8-8-1 either or lower compression.. </TD></TR></TABLE>
agreed, wild guess is below 9.0, thats a decent size dish...
Old Apr 18, 2008 | 10:51 PM
tokesGTR's Avatar
Default Re: (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
agreed, wild guess is below 9.0, thats a decent size dish...</TD></TR></TABLE>
They look like a standard dished piston, but if that's a B16 block the compression will be in the low 8's
Old Apr 19, 2008 | 01:17 AM
blinx9900's Avatar
Default Re: (tokesGTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokesGTR &raquo;</TD></TR><TR><TD CLASS="quote">but if that's a B16 block the compression will be in the low 8's</TD></TR></TABLE>
thats exactly what i was basing it off... either way nobody here can argue, were all just guessing...
Old Apr 19, 2008 | 02:22 AM
Dave_yd's Avatar
anyone i can find out for sure? like measure some things?
g0tgot
Nov 29, 2007 11:22 AM
shabam
Mar 20, 2007 11:14 PM
yeegsr
13
Dec 27, 2004 05:05 AM
ITR97-143
Jul 23, 2004 04:16 PM
turbodGSR
Apr 27, 2003 09:00 AM
