wont hold boost...help
Old Jul 13, 2004 | 04:45 PM
B18CRacer's Avatar
Default wont hold boost...help
ok, i reinstall my turbo setup on my obd1 gsr engine because I thought there might be a leak somewhere but after I started it up and run it...it wouldnt hold boost....the farthest it goes is 0.02 and thats when I'm flooring it. Here is my setup...I've got it set on stock greddy boost 8lbs.
greddy turbo kit
no fmu
no check valves
no map sensor
vafc hack set on -30 on high and lows
rc 440 injectors
holley fuel pump
msd coil and wires
b&m fuel pressure regulator set at 45psi
hayama cam gears
Could it be vacuum...if so can anyone give me a vacuum diagram for a gsr turbo.
Old Jul 13, 2004 | 05:06 PM
aznballer's Avatar
check to see if u have a leak sumwhere in the ic piping. also check to c if the turbo is secure to tha downpipe. if u have a leak anywhere it wont build boost
Old Jul 13, 2004 | 05:09 PM
B18C1CYA's Avatar
Default Re: wont hold boost...help (B18CRacer)
are you driving the car or just reving it in neutral? cus if your not driving you will not make boost there has to be a load on the motor.
B18CRacer's Avatar
Default Re: wont hold boost...help (B18C1CYA)
driving the car
Old Jul 13, 2004 | 05:10 PM
B18CRacer's Avatar
Default Re: (aznballer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">are you driving the car or just reving it in neutral? cus if your not driving you will not make boost there has to be a load on the motor.</TD></TR></TABLE>
no leak, i reinstall the whole turbo and triple check for leaks both ic and downpipe
Old Jul 14, 2004 | 09:28 AM
B18CRacer's Avatar
Default Re: (B18CRacer)
Old Jul 14, 2004 | 10:50 AM
J337_UNIT's Avatar
check the wastegate ..check its spring and whatnot..the problem could be within that since it regulates how much boost you will peak at
Old Jul 14, 2004 | 12:28 PM
CRX T-Si's Avatar
Default Re: wont hold boost...help (J337_UNIT)
Sounds like a wastegate problem to me also.
My DeltaGate is taking a **** and it's spiking at 6-8lbs. Oh yeah make sure there is no leak on your boost guage vacuum line.
I had a tee on the vacuum hose but forgot to plug the other end up and the boost guage kept telling me I was boosting 2lbs when I was boosting 5lbs and vacuum was at -10psi instead of -19psi.
Old Jul 14, 2004 | 05:02 PM
B18CRacer's Avatar
Default Re: wont hold boost...help (CRX T-Si)
thanks, ill go and check let you guys know the update
Old Jul 27, 2004 | 10:31 AM
B18CRacer's Avatar
Where do I get a new greddy wastegate...the internal one for cheap.
Old Jul 27, 2004 | 10:47 AM
pngfolife's Avatar
Check for exhaust leaks about the manifold as well, usually black streaks on the block or head where exhaust is venting to atmosphere. You can also apply regulated air pressure to the boost reference to the wastegate to see if it is opening too early.
jaydmej1
Nov 1, 2006 12:29 PM
95civhb
Aug 18, 2006 12:39 PM
trbodelasol
Mar 4, 2005 01:23 PM
nd8ch
Apr 11, 2003 12:03 AM
Immortal23
Dec 5, 2001 01:53 PM
