((((Wiseco piston CR in turbo)))
Im going to be geting 82mm Wiseco pistons with eagle rods to run in my B18C1 with t3/t04e turbo. What compression ratio is good for this setup runing around 8 to 15 psi. Thank you.
my setup is almost the exact same, only my wiesco's are at 81.5mm, i went with 9.1 cr. you'll be fine with 8.75-9.5. there are advantages, and disadvantages to all Cr's, what is the car/motors goals?
its going to be a dailly driven car with some 1/4 mile track times. Looking to get around 350hp to the wheels with Uberdata. I dont want to run too much boost with it. Just want an overall fast street car.
The reason im going .40 over is that i cant find any .30 over pistonsand i dont want to get into custom pistons.
gibson_standard_sg
Sep 22, 2008 05:29 PM
