wiseco or cp?
Old Feb 16, 2009 | 08:14 PM
jne's Avatar
jne
Default wiseco or cp?
for a ls/vtec aiming for 450whp
Old Feb 16, 2009 | 08:33 PM
bamf3000's Avatar
Default Re: wiseco or cp?
Get the hybrid wisecp's, i hear they are the best ones ever. Make a good 50 whp more.
Old Feb 16, 2009 | 08:36 PM
ITR-EKcoupe's Avatar
both are good. aslong as you arent going over 600whp, shelf wiseco's would be the way i'd go
Old Feb 16, 2009 | 08:49 PM
96 GSR-T's Avatar
Old Feb 16, 2009 | 09:57 PM
black_EM1's Avatar
Community Builder
Community Influencer
I'm partial to CP's personally. But the wind seems to be swaying towards the Wiseco. Either will be fine for you.
Old Feb 16, 2009 | 10:03 PM
mar778c's Avatar
Community Builder
Both are good pistons, but I like wiseco better.
Old Feb 16, 2009 | 10:20 PM
Honda_Mad's Avatar
What if u going over 600whp?
Old Feb 17, 2009 | 03:43 AM
b20beast83's Avatar
i will like to know
Old Feb 17, 2009 | 04:38 AM
96 GSR-T's Avatar
then you would use option 2 in the thread title......
Old Feb 17, 2009 | 04:41 AM
cotorresgee's Avatar
I made 550'ish with Wiseco gas ports 10:1 off the shelf pistons 81mm bore...Running cp's this time around aiming for 800 hp
Old Feb 17, 2009 | 04:46 AM
96 GSR-T's Avatar
I run Wiseco's too but I am tearing my motor down to run CP's before I turn up the boost, are you running the regular wrist pins?
2 very notable tuners have had the shelf Wiseco's fail in the 600hp region......
Old Feb 17, 2009 | 05:07 AM
Boosted_B_Series's Avatar
Use the shelf CPs up to 700hp, after 700 use the upgraded wrist pins.
Old Feb 17, 2009 | 06:31 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
so to save time if your set up is capable just upgrade the wrist pins from the get go and use CP pistons....that's what i would do. i like CP's
Old Feb 17, 2009 | 06:34 AM
Garcia-Racing's Avatar
CPs with upgraded wp here.
Old Feb 17, 2009 | 07:14 AM
non-VTEC's Avatar
Je
Old Feb 17, 2009 | 07:28 AM
AFI Turbo's Avatar
The shelf wiseco's have a very thin wrist pin...ive seen them bend @ the 700+whp level. They are fine with the upgraded pins.
Old Feb 17, 2009 | 08:12 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i think that is so silly. just offer the better ones.
Old Feb 17, 2009 | 08:34 AM
HYREV2NR's Avatar
Originally Posted by non-VTEC
Je
A close friend of mine has an LS/VTEC with JE's. Not sure if it's the floating wrist pins but it sounds like a VW desiel when idleing. On a cold start up sounds like it's dry and coming apart.
Anyone know what I'm talking about?
Old Feb 17, 2009 | 08:36 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i had JE on my LS vtec never sounded like that.
Old Feb 17, 2009 | 08:37 AM
HYREV2NR's Avatar
Hmmmm, too much piston to wall clearance maybe?
Old Feb 17, 2009 | 09:48 AM
96 GSR-T's Avatar
Piston Slap
Old Feb 17, 2009 | 09:59 AM
Ls_dx's Avatar
Wisecos are very good for the money, come with rings, and are good for your HP goals. I say go for the wisecos.
Old Feb 17, 2009 | 10:14 AM
Golden Eagle's Avatar
we personally use arias here but we have made 800+ hp on wiscos and cps with upgraded wrist pins with no problems and just under that with out ungraded wrist pins all 3 are brands will work for what you want its more preference
Old Feb 17, 2009 | 01:23 PM
non-VTEC's Avatar
all forged pistons will sound loud when cold. that is normal unless the piston to wall clearance is really tight (which is no good for FI)
Old Feb 17, 2009 | 02:25 PM
HiProfile's Avatar
Icon5 Re: wiseco or cp?
Not exactly. If you want to apply that overbuilding stratagy to everything, he'd have custom strutted pistons, i-beams, custom darton o-ringed sleeves, a full girdle, etc. His plans are 450whp, not 1000whp.
OTS Wisecos are cheaper than CP's, and have a long history of having very nice skirt taper. CP's cost a bit more, but you can see the design is a little better underneith. Custom Wisecos are just as good, just a little more expensive than OTS options. They also never had that issue with a certain melting of the intake-side ringlands that a CERTAIN BRAND piston did, before they "upgraded" the design.
For 450whp, you can't go wrong with either. FWIW my D16's wisecos were set to .0035" (.0038" after the coating smooths out), and its just as quiet as it was before.
