Wiring help needed
Old Mar 14, 2003 | 04:13 AM
420aNT's Avatar
Default Wiring help needed
I am putting the motor back in my 01 GSR and I cannot figure out were the wiring harness plugs go on the intake manifold. All of the damn plugs look the same and are the same color. I also have 1 extra plug left when I count all the parts that need to be plugged in. Let me know what you think I should do or can do. Maybe like the wire colors attached to each plug and what they go to? The plug in question is loacted near the secondary intake manifold solenoid it has 2 wires a blue/red and a white/red wires connected to it. Someone please help me I am going nuts. I posted this in the TECH section but got no help.
Old Mar 14, 2003 | 05:10 AM
420aNT's Avatar
Default Re: Wiring help needed (18gTeg)
ttt
Old Mar 14, 2003 | 05:35 AM
Flamenco-T's Avatar
where exactly by the secondary runner ?
there are Evap sensor ( right on top of the intake manfiold, it literally sticks up)
IAT, it's on the plenum on the intake manifold before it splits into 4 runners
IAC, behind the intake manifold
MAP, on top of the throttle body
TPS, behind the throttle body
stan
Old Mar 14, 2003 | 05:59 AM
420aNT's Avatar
Default Re: Wiring help needed (Flamenco-T)
yeah they all seem to be plugged in and the plugs are all the same color the only thing different are the color wires attached to them. I still have one extra plug left though thats the problem. Can anyone look at there car and see if they have a plug with those color wires connected to it?
[Modified by 18gTeg, 7:02 AM 3/14/2003]
Old Mar 14, 2003 | 06:26 AM
Flamenco-T's Avatar
so you did plugged all the sensor I mentioned above right ?
also, the alternator, O2 sensor plug are in the same area on the wiring loom aorudn the intake manifold, check and see to make sure that is not designed for one of them..
when I dropped my motor back on the car, I was stumbled since I have an extra plug around, I double and triple checked helms, and it turns out it was the primary O2 sensor plug..
stan
Old Mar 14, 2003 | 06:27 AM
Flamenco-T's Avatar
OOoh ****, did you plut the black intake vaccuum box back from the back of the intake manifold ?
I bet you it is the IAB box, the black plastic vacuum box behind the intake manifold, in that case, just leave it unplugged, it's a non feedback sensor
stan
Old Mar 14, 2003 | 06:28 PM
420aNT's Avatar
found it. It was a sensoe down by the crank
Dead CIVIC
Jan 30, 2008 02:53 PM
420aNT
Mar 14, 2003 03:20 AM
simple4012
Nov 26, 2002 04:59 PM
dose
Nov 21, 2002 09:15 AM
