wiring for dsm injectors?
there was a post a while ago about which way to wire dsm injectors & i cant find it.
i just need to know if it matters which way i wire them up? which wire, to which wire? thanks.
no, not the resistor box, but the actual wiring at the injectors. & not what clips to use either, but which wire to which wire. sorry, i should have worded it different.
thanks
[Modified by c1hatch, 4:35 PM 4/22/2002]
thanks
I just learned this the other day from arturbo
look at the injectors harness by your brake reservoir, there should be 8 wires all are yellow/black stripes...
use a multimeter and find each one of those wires in cirrespondence with each injectors..
cut the 4 wires, the set of wires closer to the harness, crimp them all together and connect those to the red wire on the resistor box..
the rest of the wires, connect those individually with the 4 wires out of the resistor box
this should be it....Artrubo can prolly explain it better...
stan
stan
thanks
thanks
it shouldn't matter I don;t think, they are non polarity clips...
stan
89ED
Jan 20, 2017 05:37 PM
Orangevirus1
Jul 9, 2013 07:55 AM
Mr. Vapor
May 7, 2005 01:03 AM
