wiring blue box to computer
Old Oct 17, 2007 | 03:04 PM
xiLLtegRax's Avatar
Default no start after installing turbo
ok i just installed greddy kit for my car... the car was stolen but recovered. then i replaced the key cylinder and installed the kit along with apexi tt and some gauges..so today i basically tried to fire up the car but it would NOT crank at all.... thought it was the TT somehow so i disconnect just the power to it but still wont crank. i get power for the ignition switch and no fuse blown. i used the cheap crimp-on to wire the blue box to tghe ecu just beacuse i didnt want to peel off the ecu wire... can this be the problem?? blue box is blinking so im guess its working fine but yea no crank........ anyone have any idea whats wrong??? also i have rc 440 injector instead of the 310 the one that comes with the kit..... im not sure if i wired that right but i should still get crank rite??? there is fuel pressure also..... please HELP
Modified by xiLLtegRax at 4:37 PM 10/17/2007
Modified by xiLLtegRax at 4:39 PM 10/17/2007
Old Oct 17, 2007 | 06:46 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: no start after installing turbo (xiLLtegRax)
if it is not cranking, it probably isnt ecu related. look over your tt wiring again, and check the big fuses inder the hood. the big 40-50 amp guys.
Old Oct 17, 2007 | 06:59 PM
xiLLtegRax's Avatar
Default Re: no start after installing turbo (boostedcivicsir)
i actually disconnect TT wires to see if it was it..... i didnt disconnect from ecu but did disconnect from the ignition so it wont get power but the engine didnt turn
Old Oct 18, 2007 | 05:02 AM
blaze the chemi's Avatar
Did you hook the MAP sensor up right to the blue box? If you get those backwards it won't start. Plus you should get the 310cc if your using the blue box. 440's will be too rich.
Old Oct 18, 2007 | 08:52 AM
Mr. Badwrench
Default Re: no start after installing turbo (blaze the chemi)
ok before we go any further,
IS THE CAR CRANKING?
if the engine isnt even spinning the bluebox has nothing to do with it.
Old Oct 19, 2007 | 03:46 PM
soaringchimp's Avatar
Does the car have an alarm? If it has an alarm make sure the starter kill isn't engaged for some reason. If no alarm check the switches on the clutch pedal. Starter wont engage if the clutch lever is not pushing the switches locate near the pivot point of the clutch lever.
xiLLtegRax
Dec 26, 2007 07:06 PM
xiLLtegRax
Oct 21, 2007 03:56 PM
EJ8 D15Y8
Sep 22, 2004 06:15 AM
turbod16y7vtec
Dec 12, 2002 08:48 AM
