wired in 880's and 3bar
i've posted this a couple times but havent found the problem. my car was running fine, i added the 880's which in had to convert to peak and hold so i used individual 10ohm 10 watt resistors for each injector and i wired in the 3 bar map sensor. how would i know if i did this right?? i also put the aem ems in and when i drive i cant pass 6k rpm. so its either the injectors, 3bar , or not tuned right. how do i know if i wired the injectors and 3 bar map sensor correctly?????
You said you put in injectors/3bar/AEM all at once?
Have you properly tuned your AEM for the 880's?
Have you checked to make sure you have 12-15ohms across the ecu pins for the injectors?
Have you checked voltage output for the map sensor?
for the inejctors just check the ohm resistance between the 2 pins it should be like stated above 12-15 range. the 10ohm 10 watt resistors should inline on the power yellow-black wire.
After adding the 3bar map with your ems, you have to do more then just select the sensor in the wizard.
Your going to have to rescale your fuel and timing map accordingly. or your gonna have a melted pile of aluminum.
im sorry, i have absolutely no help for you, but why in the world?? what is your set-up, engine tranny chassis wise? just interested cause ive never heard of a honda with 880s and 3 bar.
im working on a new calibration for you.. should have it done tomm early afternoon. had some stuff come up and couldnt get to it today.... im sure we will get it figured out soon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluesi00 »</TD></TR><TR><TD CLASS="quote">im sorry, i have absolutely no help for you, but why in the world?? what is your set-up, engine tranny chassis wise? just interested cause ive never heard of a honda with 880s and 3 bar.
Heh... That's exactlly what I run aswell....
precision 880's and gm 3 bar map on my EMS..
Good luck with it man...
Hey Jdogg......wanna make me some calibration? trying to tune my EMS on my99 accord......i asked question on the EMS fourm, and a few of the tuners said they have done it. i just wanna tune it untill i can get a hold of some 550cc injectors. i'm not gonna push more then 7psi on my stock injectors and stock MAP, but when i get my injectors and 2BAR map, it's gonna be a different story. i got it running preety good, but maybe u can do something better, but i would guess u would have to put seat time in to do it....
anyone?
anyone?
turbotegsedan
Jun 1, 2012 12:02 PM
