Which wire to tap for Air/Fuel gauge?
The instructions say not to tap directly off of the O2 sensor wire, but rather off of the wire going to the ECU. On a PR3 ECU, which one is this? Thanks
Re: Which wire to tap for Air/Fuel gauge? (integracon)
If the wire off the O2 sensor isn't shielded I think you can just tap that, thats what I did, and it works fine. Otherwise, I dont know the exact wire
Re: Which wire to tap for Air/Fuel gauge? (SlowB16)
I didn't think it was shielded until I got no reading, just one LED lit on the Rich side.
The PR3 ECU is from the JDM B16 engine. PR4 is the 91 integra ECU, etc.
What is a good wire to tap the red wire into? I know it says ignition start wire, but is there an equivalant wire that is easier to get to?
New User
Re: Which wire to tap for Air/Fuel gauge? (Giuseppe)
I have a 97 GS-R. I tapped the A/F gauge into the fattest white wire. I did this as close to the ECU as I could get.
Re: Which wire to tap for Air/Fuel gauge? (Anthony K)
Just a note... for the A/F gauge make sure to get ground from chassis ground or the actual ground wire at the O2 sensor... else it can be somewhat (more?) inaccurate.
Dustin
Dustin
New User
Forget it, just had to let it warm up
