Wire Diagram
Old Apr 25, 2012 | 11:29 PM
madgeo's Avatar
Default Wire Diagram
So im working on my del sol to finish boosting it. I dont have AC in the car and want to use the AC button to switch from a low-high setting for boost. I was wondering if any one has done this? If so, what wires r used or can someone explain what they did to make it work. I have the AC button tooken apart from the cluster and have the 4 white wires and 1 red one. Any help or diagrams posted/sent would be help & greatful..... Thanks
Old Apr 26, 2012 | 04:59 AM
Turbo-LS's Avatar
Default Re: Wire Diagram
Well if your running a Honda ecu based engine management I think you can program that right into the software. If your running some other setup like external boost controller plug the switch back in and use an electrical tester and see watch wire has voltage output to trigger your external system
Old Apr 26, 2012 | 04:46 PM
NonovUrbizniz's Avatar
Loved
What management do you have?
I did a quick search and for hondata it takes rewiring the switch. So it's almost pointless IMO. I'd just get an external switch and wire that that the input on the ecu.
The AC switch option is more for ciche factor than anything.
Old Apr 26, 2012 | 05:09 PM
nealnanoHX's Avatar
Sleeper factor too.
Old Apr 26, 2012 | 05:55 PM
Loved
Originally Posted by nealnanoHX
Sleeper factor too.
Adjective
ciche
quiet, silent
Old Apr 28, 2012 | 08:33 PM
madgeo's Avatar
So after finding out that the AC button will only work once. Due to that its only a 5amp draw, and running 12 volts. Will cause it to burn inside. Only giving it 1 quick use. I can use an external button/switch or defrost button....
chad
Mar 27, 2009 06:59 PM
96 GSR-T
Mar 31, 2008 06:55 AM
Pzn801
14
Feb 9, 2007 05:39 PM
